# Still no smart smoothing on raceroom?
**URL:** <https://forum.openmr.com/t/still-no-smart-smoothing-on-raceroom/40825>\
**Category:** Discussion\
**Created:** [June 15, 2023, 5:37pm UTC](https://forum.openmr.com/t/still-no-smart-smoothing-on-raceroom/40825 "2023-06-15T17:37:41Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![SpencerGrant](https://forum.openmr.com/letter_avatar_proxy/v4/letter/s/48db29/32.png) [@SpencerGrant](https://forum.openmr.com/u/SpencerGrant)\
**Post date:** [June 15, 2023, 5:37pm UTC](https://forum.openmr.com/t/still-no-smart-smoothing-on-raceroom/40825/1 "2023-06-15T17:37:41Z")
</div>
2 years ago, Smart smoothing stopped to work on Raceroom (5k+).
Just tried with the last Client 1.11 and it still doesn’t.
But there is something I don’t understand, in this post I found on internet, the guy (8KX) says
“I tried the 120hz last night in **RaceRoom** and was astounded how good it ran. I use a RTX3090 and had mostly highest settings on with SteamVR resolution of 2828 x 2828 and the image was really good. But more importantly, hotlapping as only car I was holding 120 FPS and it looked fantstic, very smooth and stable with a bright and crisp image. I then tried with field of 20 cars and using fpsVR it said I was only at 60 odd fps at start of race **however I had Smart Smoothing turned on in the Pimax Client and it was extremely smooth** without any of the ghosting or artifacts I usually would see which is reason why I never have smoothing or reprojection turned on. Don’t know what the Pimax engineers have done but this is so good and to run at 120fps as well. Most tracks, except Nords, the frames jump up after the race start but everything remained super smooth.”
So is there a way to run Raceroom with smart smoothing?
[https://forum.kw-studios.com/index.php?threads/pimax-8kx-dmas-rev-2-120hz-is-fantastic.18908/](https://forum.kw-studios.com/index.php?threads/pimax-8kx-dmas-rev-2-120hz-is-fantastic.18908/)
**Post date:** [August 14, 2023, 5:37pm UTC](https://forum.openmr.com/t/still-no-smart-smoothing-on-raceroom/40825/2 "2023-08-14T17:37:56Z")
</div>
Closed on August 14, 2023, 5:37pm UTC
