Well +1 here too, brightness looks better without compromising colours + 2k resolution built-in. What im interested about is does the blue light filter still work because it looks so much brighter now without even using cool mode.
Hopefully we get some-kind of slider or at least an similar option to easily turn on/off enhanced brightness. Good job anyhow for the price of Pimax Headset im actually pretty happy things are getting fixed. Imho you need to get a file hosting service for us on different continent so we could actually download games/videos you are hosting on piplay and for steam games i would move those linked game to a different tab so when iām checking content on piplay it wont swap me on steam webpage or to china bbs.
does the brightness need to be adjusted each time ? or does it remember settings ?
It seems to need to be changed if you change modes. You can now see the status including if the cool or warm colors are selected, in the debug tools. Very handy.
The brightness really makes things much better. 3d effect is so much more noticeable and colourās look brighter and more vibrant.
The brightness setting may retain. If you check the status from the Debug Tool/Device info/Connection, Brightness information reads LEVEL_HIGH_1 or LEVEL_NORMAL.
Perhaps the Debug tool gets stuck when modes are changed. Mine reads LEVEL_HIGH_1 even after USB unplug/replug.
Anyone know if it can go higher than LEVEL_HIGH_1?
The tool was written in C# .net. Itās therefore very easy to disassemble it and you can then see all the commands. There are also 2 commands for lower-than-normal brightness but I donāt think anyone is interested in that
Iām not at home right now. Iāve tried it yesterday quickly, I donāt think it changed much over HIGH_1 though, but Iāll need to look closer again I guess
Iād say there is a significant change between HIGH_1 and HIGH_2, but I think you start loosing contrast and the blacks begin to appear a bit grayish. After experimenting I personally prefer 1, but itās good to have the option to increase it further if I ever need to
BTW, you donāt need to restart Steam VR to change between brightness levels, you can do it in the middle of a game so itās easy to compare.
Noticeable change, indeed. As jjvvgg, mentions about the colors. It begans to wash them out slightly. If itās not too much trouble, Iād like to know the lower than normal brightness settings as well, sjefdeklerk.
Wondering how close ReShade in Extended mode can match or come close to LEVEL_HIGH_1.
Hello sjefdeklerk ~!
I made a video using your amazing information.
I was able to see how bright it was while changing the brightness.
Thank you for your information.
