# SlimeVR Tracker Project is Live
**URL:** <https://forum.openmr.com/t/slimevr-tracker-project-is-live/36879>\
**Category:** Controllers\
**Tags:** mocap\
**Created:** [August 31, 2021, 9:25pm UTC](https://forum.openmr.com/t/slimevr-tracker-project-is-live/36879 "2021-08-31T21:25:38Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Krunchy](https://forum.openmr.com/user_avatar/forum.openmr.com/krunchy/32/23532_2.png) [@Krunchy](https://forum.openmr.com/u/Krunchy)\
**Post date:** [August 31, 2021, 9:25pm UTC](https://forum.openmr.com/t/slimevr-tracker-project-is-live/36879/1 "2021-08-31T21:25:38Z")
</div>
[SlimeVR Full-Body Tracker | Crowd Supply](https://www.crowdsupply.com/slimevr/slimevr-full-body-tracker)
Full body tracking starting at $165 USD. No base stations required.
**Author:** ![Omniwhatever](https://forum.openmr.com/user_avatar/forum.openmr.com/omniwhatever/32/27218_2.png) [@Omniwhatever](https://forum.openmr.com/u/Omniwhatever)\
**Post date:** [August 31, 2021, 10:07pm UTC](https://forum.openmr.com/t/slimevr-tracker-project-is-live/36879/2 "2021-08-31T22:07:13Z")
</div>
As reliable FBT gets cheaper, hopefully it’ll be used in more games with developers able to expect more people to have it and be worth investing the time. Because unless you spend a crazy amount of time in VRChat, there’s not really much else which makes good use of it and feels like a waste right now. I guess there’s kind of B&S, but still quite the small list.
**Post date:** [August 31, 2021, 11:25pm UTC](https://forum.openmr.com/t/slimevr-tracker-project-is-live/36879/3 "2021-08-31T23:25:05Z")
</div>
This looks interesting.
**Post date:** [September 1, 2021, 12:08am UTC](https://forum.openmr.com/t/slimevr-tracker-project-is-live/36879/4 "2021-09-01T00:08:55Z")
</div>
There have been a couple reviews out there by Thrillseeker, Phia, and The Mysticle. They had early units and the software was pretty primitive, but later reviews definitely showed progress on that front. Plus it’s opensource and they have the schematics and software out on github if you wanted to make your own. You are pretty much limited to VRchat and Blade and Sorcery for this type of support. Personally, I don’t think I’d use it in Blade and Sorcery - too easy to kick something I might like.
**Post date:** [October 31, 2021, 12:08am UTC](https://forum.openmr.com/t/slimevr-tracker-project-is-live/36879/5 "2021-10-31T00:08:58Z")
</div>
