Hi everyone, I’m looking for some advice.
I’m using a Dream Air SLAM, and for the past two weeks I’ve been running it through the Pimax EVO using the Sboys3 driver and SteamVR. In DCS this gave me a noticeable performance boost — I was able to maintain a stable 90 FPS with very good image clarity.
My system:
AMD Ryzen 9 9850X3D
Nvidia RTX 5090
64 GB RAM
Yesterday I launched DCS again after not playing for about two days, and immediately noticed a drop in image quality. It looks as if the effective resolution has decreased. I didn’t change any settings at all. The only thing I did was update the Sboys driver to version 1.3.0‑beta1.
After rolling back to 1.3.0‑beta0, the image quality did not return to what it was before.
My question is:
Does the Sboys driver normally reduce the effective resolution in the headset and I simply didn’t notice it earlier? This seems unlikely to me, because the difference was obvious right away.
When I switch to OpenXR, the image is sharp again — but the FPS drops by roughly 10%.
Do you have any idea what could be causing this?
