Razer Hydra compatibility
Will the 5K/8K work just as well as the 4K with Razer Hydra controllers?
Thanks.
Dear Wildcopper, we need check internally first and suppose to update to you by tommorrow.
confirmed, 5k/8k will work with Razer Hydra controllers. thanks for your supports!
