# Q.U.B.E Directors cut
**URL:** <https://forum.openmr.com/t/q-u-b-e-directors-cut/41140>\
**Category:** Game On!\
**Created:** [September 14, 2023, 10:51pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140 "2023-09-14T22:51:10Z")\
**Posts on this page:** 20\
**Page:** 1
<div class="post-metadata">
**Author:** ![Malcolm](https://forum.openmr.com/letter_avatar_proxy/v4/letter/m/e19b73/32.png) [@Malcolm](https://forum.openmr.com/u/Malcolm)\
**Post date:** [September 14, 2023, 10:51pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/1 "2023-09-14T22:51:10Z")
</div>
Hi. I have this game on steam. On clicking play I see an option to run it in VR on Oculus Quest.
How do I get it running on Pimax?
I’ve tried running it from Pitools with no luck. Anything I try just runs it in a little window on the desktop.
Thanks
**Post date:** [September 15, 2023, 4:27am UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/2 "2023-09-15T04:27:58Z")
</div>
Hello,
If you launch from SteamVR Home, does it crash and display an error message? Also, do you have Revive installed?
**Post date:** [September 15, 2023, 1:39pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/3 "2023-09-15T13:39:31Z")
</div>
Hi.
I haven’t used VR in some time.
When I go to SteamVR Home the game is not in the list. If I go into the SteamVR menu it’s not there in the library but if I click View All it opens up Bigpicture or whatever it’s called on the desktop, must be a new update.
If I run it from that again it just opens up on the desktop on a small window.
I have no idea what Revive is so no I don’t have it installed.
Thanks for your help.
**Post date:** [September 18, 2023, 7:19am UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/4 "2023-09-18T07:19:55Z")
</div>
You may check this post - [Steam Community :: Guide :: How to set up Revive](https://steamcommunity.com/sharedfiles/filedetails/?id=1401048874)
**Post date:** [September 19, 2023, 6:31pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/5 "2023-09-19T18:31:27Z")
</div>
Thank you. I remember playing Oculus games and also Steam games in Oculus mode for better fps without this in the past but I remember posting on here before that I could never get Sneaky Bears to work. I see in that link that game so hopefully this will fix that too.
Many Thanks.
**Post date:** [September 19, 2023, 6:32pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/6 "2023-09-19T18:32:49Z")
</div>
If I used the inject function it still just runs on the desktop. Nothing in the headset.
**Post date:** [September 21, 2023, 3:13am UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/7 "2023-09-21T03:13:34Z")
</div>
Did the game move to PimaxPlay - “My Assets”?
Try to launch the game from PimaxPlay.
**Post date:** [September 21, 2023, 11:42am UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/8 "2023-09-21T11:42:03Z")
</div>
Hmm I don’t have that. I use Pitool at the moment.
I checked in Pitool and the game is showing in the My Games section.
When I click start it just opens in a window on the desktop as usual.
**Post date:** [September 21, 2023, 8:20pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/9 "2023-09-21T20:20:33Z")
</div>
I installed PimaxPlay. It’s all dark and horrible. 🤮
The game isn’t showing in ‘My Assets’
**Post date:** [September 22, 2023, 7:25am UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/10 "2023-09-22T07:25:15Z")
</div>
Did you configure the settings on PimaxPlay?
> [@Malcolm](#):
You’ll need to relaunch PimaxPlay so it can scan your Steam library and add the games to “My Assets.”
**Post date:** [September 22, 2023, 2:05pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/11 "2023-09-22T14:05:14Z")
</div>
Nope it doesn’t show in Assets in PimaxPlay. Restarted it several times.
Also how do you get the games in that to list alphabetically like they were in Pitool? They seem to be in some random order which makes finding games in it a bit harder.
**Post date:** [September 25, 2023, 10:01am UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/12 "2023-09-25T10:01:43Z")
</div>
Hmmm, perhaps you might need to launch the game from Steam rather than PimaxPlay. We are currently in the process of developing a feature that will enable users to manually add games to PimaxPlay’s assets.
> [@Malcolm](#):
Will be organized according to various platforms for ease of use.
**Post date:** [September 25, 2023, 1:24pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/13 "2023-09-25T13:24:09Z")
</div>
Nope just runs in a window on the desktop.
Oh well. Thanks for your help.
Having them in a random order does not make it easier to use. There doesn’t seem to be any logic and their arrangement. An option to list alphabetically would help a lot if you could pass that request on the developers.
**Author:** ![BrziJoe](https://forum.openmr.com/letter_avatar_proxy/v4/letter/b/cab0a1/32.png) [@BrziJoe](https://forum.openmr.com/u/BrziJoe)\
**Post date:** [September 26, 2023, 6:12am UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/14 "2023-09-26T06:12:22Z")
</div>
Hi, I think I saw somewhere before that this game was compatible with first oculus only (DK1?). Maybe it was updated since, I do not know. But better check steam hub for this game, what other people said.
**Post date:** [September 26, 2023, 1:37pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/15 "2023-09-26T13:37:46Z")
</div>
Thanks for your input. check Steam hub?
**Post date:** [September 26, 2023, 1:42pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/16 "2023-09-26T13:42:23Z")
</div>
Find this game on steam, click it, and you will find “community hub” somewhere; there you can find discussions, artworks… Check discussions first, then guides, feedbacks…
**Post date:** [September 26, 2023, 6:19pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/17 "2023-09-26T18:19:43Z")
</div>
Ah I know what you mean now. Thanks I already looked in discussions of Steam. No mention on Pimax so that’s why I posted here to get help from people who have Pimax headsets.
**Post date:** [September 26, 2023, 6:20pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/18 "2023-09-26T18:20:14Z")
</div>
Does Pimax not play first Oculus games?
**Post date:** [September 26, 2023, 6:42pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/19 "2023-09-26T18:42:11Z")
</div>
DK1 was first vr, completely different. Games at that time was hard coded for DK1 only.
After that time vr came in more friendly coding for general vr.
**Post date:** [September 26, 2023, 6:51pm UTC](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140/20 "2023-09-26T18:51:22Z")
</div>
Ah thanks for knowledge. I can safely just give up on this game now then and just play it on my monitor.
It is supposed to work in Vorpx but I believe it’s just 2D.
Can’t believe they haven’t made a game like this and Portal for VR. Seems like basic VR gaming to me.
[Next page](https://forum.openmr.com/t/q-u-b-e-directors-cut/41140.md?page=2)
