https://1drv.ms/u/s!AqfoHBlbUXDTiqsHT7Abh_ZHYM6J9g?e=za0ZzD
254a link
I know its buggy but may be worth listing for a raw performance benchmark?
254a link
SN203. Ghosting with 144Hz too.
Yes, it’s sad
My brain is getting used to the 120/144hz drug and I can’t go back to 90hz anymore… going back is a hard punch.
i just got a nice mixture with pitool 253 and FW 264, it works flawless with the 8k+ 110 Hz and get the performance and gpu utilization 90-96%
do you get the ghosting effect when you use 110hz ?
ghosting should be a normal thing if your perfomance with 8k+ cant hit stable 110 fps or should be also visible when SM is enabled and more visible if cant hit stable 55 fps but at 5k+ (204 rev) at 144hz/72 there is no ghosting inside sims . Higher refresh rate gives me genrally less ghosting when used with SM.
Based my test:
stable 90/45 with SM = playable but visible ghosting at some objects
stable 120/60 with SM = acceptable minimal ghosting
stable 144/72 with SM = no ghosting inside vehicles ( plane , cars) only visible at external chasing cameras.
*SM = SmartSmoothing On
No i don’t , have you tried to lower your ingame settings or ss?
I use Pimax 5k+ (SN203) and I have stable 144fps in Beat Saber (flat graph of cpu/gpu usage, no spikes), but still there is strong ghosting (even in Menu). Less ghosting in 120hz (but it exists)…
So, please, stop writing about “you don’t have stable fps” or “it is because you have Smart Smoothing enabled”… Again, I have stable FPS and no Smart Smoothing enabled…
i have stable 55 fps sm on . its like when you se left and right fast you can se ghosting in fps vr etc
oke maybe is the frametime to high? First thing i would try is to get the frametime lower
I have rev 204 so your problem is probably 203 rev. issue with PT or game specific
Maybe it is SN203 only issue, but the problem exists, and I hope it will be fixed.
The issue is reproducible everywhere for me, I mentioned Beat Saber only as an example.
Exactly same for me 203
Yup same bug here on my 5K+ 203
jaggy/shifted/distorted/wavering picture on the lower half of the right panel. The left panel and upper half right was OK
Hopefully they can make the catalyst slider perform as it is supposed to do, or offer a toggle, in future releases.
Yes i have ghosting.
and its not being over driven, frame time around 7.2ms
8k+ FW264 PT253 ( all of them that i have tried to be honest 249,253,254, 255, 258,259,260 )
and these stupid white bars…
Ok so the firmware is buggy then , just go down to 90 hz and the ghosting is gone
Please tell to the community Cpu, gpu, the resolution you are gaming, PP on or off , and the games where you have ghosting
Ok , i found it. 254 is the best for you (8K+ goig well with 254) and
you have i7 and 2080S
Hi Fabrizio,
Atm 253 ( cant run 254a) PT rendering at 1.25
Steam VR stable branch at 100% to 88% scaling
Yes i9700k @5G, 2080S
no PP, no FFR, only just hidden mask.
Only really use iracing…( bit of time on other games but not much to bench mark accurately )
But FW264 does do 110HZ ,but i get a little bit of ghosting ( like panel persistence)
I get little white bars on the side at 110hz which is not there at 90hz.
Im staying at 90hz atm
Im happy enough with that , but im interested in hearing from other members to see of GPU is an issue for them or maybe holding back the FPS they get in games. ( this is the issue that i face)
Yes 254 is the fastest but it crashes after 50minutes
