Hands do work for me.
Hmmm, I cannot get the hands working for the life of me. Weird.
Definitely digging this program though.
One thing I noticed is for imported apps the Title is displayed, even if you choose not to display titles on the apps in the overall library.
I tried imported VAM in PE but it will not load but I was able to import and run it before I installed PE. Now I get PE up and running then lanch VAM from my desktop them but on my 8K+. small problem compared to MFS list of problems in Desktop.
Thx for your answer.
I think Iāll wait then - I already did some undervolting / OC tweaking with my 2080 Ti the last three days, so I think I donāt need any potential error & crash cause in addition right now
But Iāll keep an eye on it, and as soon as my UV/OC experiments worked for a couple of days, and the next beta release has mouse mode enabled directly, Iāll have a look at PE
@SweViver a couple apps Iāve imported require a command line parameter. For example: ā¦exe" -vr
Is there a way to add command lines to imported apps/games? I canāt seem to find a way to make it work.
@SweViver:
Yes, I would appreciate that too.
I.e. the truck sims (ETS2 / ATS) launch in VR only with ā-openvrā or ā-oculusā. From within steam, ā-openvrā, no problem. But if I could use ā-oculusā from PiTool / PE directly, I could deactivate Parallel Projection and perhaps gain a significant amount of FPS
In that case, I just want to mention, that Iād need a second parameter for both simās as well in order to point to the mod-file-directory
So at first, one command line parameter would be nice for verfying whether ā-oculusā without PP would work, second, expanding that function to several parameters would be perfect.
Thx already for having a look at that somewhen
Wonderful, installing PE independently by just running an installer will be great, I assume the installer will take care of stopping the required Pitool applications and services as well as having a checkbox at the end of installation saying
[ ] Start PiTool
what would also be nice is to include a change log in the installer either before clicking install or after when its done.
When the src is on Github will releases be distributed through the releases tab?
This would also be great as we can simply watch releases.
Also how about adding an auto updater in PE itself? You can check on start up @SweViver
Yes this needs to be a priority wish list feature, it makes a beutiful ui kind of crappy.
@SweViver could maybe add an option to quit steamVR upon exiting a game
Does this work with Handtracking, this would be a kikler app for me?
weird I thought @SweViver already added this option, check the json files in one of those Pimax folders(maybe the one in Appdata\LocalLow\Pimax
Wow, VR SLI on PE, great work!! that makes I want to see the next releases.
What Iāve been doing tonight is exiting games by bringing up SteamVR menu and selecting Exit VR in the bottom left hand corner instead of exiting back to SteamVR Home. This takes me right back to PE rather quickly.
Having the ability to add custom command lines to the executable, and having a portrait game cover image layout would be absolutely perfect. Iām really liking this so far.
starry sky and a blue stripe, nothing else does not work for me.
Latest nvidia drivers, antivirus nod, disabled.
I donāt have steam in folder C
Same for me, had it working yesterday no problem too, I either get the blue line or if I unchecking the home box, I just get the Pimax logo.
So frustrating as Iāve uninstalled everything twice including steam vr.
What worst is I was having an unbelievable time with Iracing, looking fabulous, but if I just laid up the pre release way, it now looks pants.
Doug
@SweViver, a command line per game for several parameters is totally necesary for a lot of games and mods.
I guess we canā t use the command line parameters set in SteamVR and Oculus, or am I wrong?
Until there is one, I will not use Pimax VR Experience, a pity.
Any ideas why I get a blue line through the starry background and nothing else when attempting to get/see the PE screen, also if I turn off or uncheck the home button discusses I just see the PT logo.
Where should I report issues I run into?
Sorry guys Ive been busy this weekend doing a video about VRExp.
First off, it seems some of you dont see any UI upon start? Did you try to recenter the view? (Middle mouse button) or HTC controller touchpad click or Index controller thumbstick down)
I see the focus of the view with the knuckles and I press the button and the blue line goes from being down to being up, but I donāt see anything else
I have also tried to go back to do the configuration of the room pitools, and nothing changes
Hello
I had everything work well yesterday, Iracing blew me away, enough for my brother to drive miles to try it out before ordering his own 8KX, honestly, i was totally blown away after using PE, so simple to use, and alter the settings, great job.
But today if I check " Start Pimax VR home " I see only a starry sky universe with a blue line running or pointing into the distance, similar to a pointer, which i can move if i hold down the thumb stick.
If I uncheck the " start pimax VR Home" i get a less starry image but wit a white PT logo which doesnāt do anything.
Everything is tracking as i should, but now that Iāve used the PE i cannot get iracing looking anything as sharp as i did yesterday, which is so disappointingā¦
Any help please.
Doug.
Iāve tried everything to get it to work again.
Uninstalled Steam VR, everything i could find for Pimax, and reinstalled over and over.
Running out of ideas.
Doug.
