# Pimax VR Experience 0.74.0.0 Beta
**URL:** <https://forum.openmr.com/t/pimax-vr-experience-0-74-0-0-beta/33580>\
**Category:** Release Notes\
**Tags:** beta\
**Created:** [December 1, 2020, 6:33pm UTC](https://forum.openmr.com/t/pimax-vr-experience-0-74-0-0-beta/33580 "2020-12-01T18:33:35Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![SweViver](https://forum.openmr.com/user_avatar/forum.openmr.com/sweviver/32/3917_2.png) [@SweViver](https://forum.openmr.com/u/SweViver)\
**Post date:** [December 1, 2020, 6:33pm UTC](https://forum.openmr.com/t/pimax-vr-experience-0-74-0-0-beta/33580/1 "2020-12-01T18:33:35Z")
</div>
## Update History
## [0.74.0.0 Beta](https://community.openmr.ai/t/pimax-vr-experience-version-0-74-0-0-beta-available-now/33579?u=sweviver)
What’s new:
- **New** : Backlight brightness can now be adjusted in real-time without reboot, range: 0-100 with 1.0 granularity.
- **New** : Backlight brightness now supported on all Pimax headsets, including 8KX.
- **New** : Added brand new Image Calibration page with dynamic image adjustments, selectable test charts/images and ability to quick save changes to profiles.
- **New** : IPD Offset & Screen Vertical adjustment sliders now can be linked to adjust both sliders simultanously. Individual per-eye adjustment is still possible.
- **New** : Added icons/indicators to the IPD Offset & Screen Vertical adjusment, to illustrate what the sliders are doing.
- **New** : All Drop-Down menu selections are now dynamically made upon selecting new value, without the need of using a “Load” button. All Load-buttons for drop-downs have been removed to improve user experience.
- **New** : Displaying the selected Profile Name in “Settings” & “Profile → Edit Profile” pages, to make it clear to the user the currently loaded profile upon a new selection in drop-down menu.
- **Update** : Core: Refactored launching VR games via PE.
- **Update** : Installer: Updated and simplified the installer of PE, for PiTool team, to have it bundled with PiTool installer. Standalone installations of PE still uses the previous installer.
- **Update** : Corrected the selection of Refresh Rates for each Pimax headset. Non-supported modes are no longer displayed nor selectable.
- **Update** : Corrected the selection of FOV modes for each Pimax headset. Non-supported modes are no longer displayed nor selectable.
- **Update** : Reversed the order of IPD Offset & Screen Vertical values - to +, for correct logic and applied natural design to slider behaviours.
- **Update** : Refresh Rates are now sorted in ascending order.
- **Fix** : Sometimes command lines for a game were displayed twice in the list.
