Hi
Now it is more than an year that I replaced my Reverb G2 with a Crystal Light and there is still one thing I don’t understand.
G2 controllers didn’t have the finger “tracking” functionality, but they resulted in a clear behavior in all the games; pressing the finger trigger resulted in the movement of the index finger in game (such as Half Life Alyx) and the handle button resulted in the rest of the fingers to close together.
With the Pimax controllers the first button is behaving the same way as G2 controllers, while the handle button never closes the hand in the games.
For example in Half Life Alyx I cannot close the hands.
Do I have to change something in PimaxPlay to have Pimax controllers to behave like the G2 ones?
Thanks
So is it possible to close the hands in Half Life Alyx?
How to do that?
I remember something about using “Occulus” being the option to use for the controller. Been a while since I played it, can’t remember if it was in the game or SteamVR setting for the game…
do you mean a controllers custom binding?
Yes, pretty sure it was that. You leave the default (no changes) inside Alyx.
In SteamVR controllers binding you can change it on a per-game basis, it’s there where the change needs to be made IIRC. If there isn’t a custom one already in there then you’ll have to make it for yourself.
