Pimax Play 2.x "Foveated Rendering"
Hi all, my Google-fu is letting me down, so I thought I’d come and ask. Apologies if it has been; I can’t find an answer.
In Pimax Play up to 1.4.x, there was a very clear option to enable foveated rendering and select how aggressive it was. I used this in Elite Dangerous and found it was quite useful.
As of Pimax Play 2.x I can only find Eye tracking and Quad Views, with the latter having the aforementioned settings. Has it gone away, or am I just blind? :slight_smile:
at the lower left corner is a “advanced” option. select that and see if you see what you are looking for after that.
So it’s now part of Quadviews. Okay, thanks both - much appreciated!
