Pimax Play 2.04 cropping (still not 0%)
Hi, just tried out 2.04. Everything seems to work fine on crystal light.
However I was keen to try the cropping feature again, and finally get rid of xr toolkit.
However even though I used custom and set all the horizontal crops to zero it still crops the horizontal fov.
I end up looking through a clearly defined rectangle, unlike when I crop with the toolkit and get a much more pleasing circle with the top and bottom cut off
Hi, saw some comment on discord about making sure 2.04 was a clean install so no settings from previous were left behind. I’ve just done a full windows reinstall and then installed 2.04 fresh.
Problem is still there 0% horizontal cropping still gives me a rectangle viewport. This rectangle also has a band around the edges of a darker blue and a pale blue (pretty sure this was there on my previous attempt as well}
so with a 30% vertical crop and 0% horizontal crop my view is a dark blue rectangle a few pixels wide with a pale blue rectangle inside it with the normal image inside that.
No toolkit had been installed when I tried this so there was no conflicts.
I will just add that cropping works fine in all the available openxr toolkits that ive tried and also works fine with Lemans Ultimate’s new built in cropping.
I’m using crystal light and had same issue in normal and wide fov mode.
Thanks
Noted. I’ve forwarded this to the dev team, but it’s not fully optimized yet.
