Pimax Play 2.0.2
Same issues i reported about 2.0.2/2.0.3 still have not been fixed in 2.0.4.
Same FOV issues(anything other than WIDE FOV becomes Square boxes instead of naturally Round, and custom FOV just gived the boxes even smaller with a black bar in the middle of your eyes…so for example again… Normal FOV is just Square boxes in your Headset instead of natural looking/shorter FOV)
this issue didint exist in 1.44 and below.
This is something they’re now doing and ignoring P2 headsets???
And the Inverted PP on and off box issue still there(on is OFF and OFF is ON)…
none of the things i reported and sent was fixed.
So, for my P2 headsets i am forced to stay 1.44 and below.. :frowning:
8KX in Elite Dangerous have black box in center, I had to go back to the 1.44
Yup, Any P2 headset of V2 of piplay is broken and should be avoided for FOV and PP issues.
(5k Plus and Super, 8k and 8KX)
I upgraded from 1.44 to 2.0.2 on the Dream Air and had an issue with the horizontal FOV being totally squashed (“Normal” FOV selection). View became an upright rectangle. Also Smart Smoothing in SC suddenly showed constant glitching everywhere.
Reverted quickly back to 1.44 and thankfully that’s still working fine despite the fw upgrade from 1.02 to 1.03.
New issue, with 8K-X:
I was fine on 2.0.2 for months since its release. Then, I tried versions 2.0.3 and 2.0.4 both. I went back to 2.0.2 in both cases due to the broken FOV crop.
Now the problem: When going back from 2.0.3 to 2.0.2, everything was fine for me: FOV “normal” was set and saved properly, and I was able to play as usual. (No Crop issues here, btw, all like with 1.44).
When I now went back from 2.0.4 to 2.0.2, saving of the FOV “normal” is broken => Always when opening PiPlay, the FOV displayed in the HMD is “wide”, although the PiPlay-Setting shows “normal”. I have to hit “confirm” in order to have the HMD display “normal” correctly. As soon as PiPlay is shut down and re-opened, HMD-FOV itself is set back to “wide” again, while PiPlay shows “normal”. Confirming “normal” again is working - until closing and re-opening PiPlay again. And so on.
I already made a complete clean uninstall including deleting all remaining PiPlay/Pimax folders manually and doing a complete clean re-install afterwards.
=> Seems, as with 2.0.4 something with saving the FOV settings properly to the HMD is broken and doesn’t get fixed when falling back to 2.0.2.
Suspect it was the firmware update, same happens here. Have to wait for a new fixed firmware version I guess.
Regarding the black box appearing with the P2 headsets, I’ve asked the dev team to conduct some tests again.
@PimaxQuorra What’s the latest on this? I’m still on 1.44.2 because I don’t want to get the FOV bug again on the Dream Air.
Is it an autoinstaller issue? If so, can I do a manual clean uninstall and install to work around it?
I’ve Googled the process, but wondering if you can confirm from the Pimax side the correct procedure ie what caches / hidden folders should we delete etc
Did you try the 2.0.4?
When you do the installation, make sure you have checked the “Clean Installation”.
It was 2.0.2 at the time. Does 2.0.4 have any fixes for that? I can try again but I’m nervous about it because things are working. I don’t want to trigger problems that are difficult to revert from.
However even now, after manually uninstalling 2.0.2 and reinstalling 1.44.2, on PiPlay launch I often just get a blank window. Sometimes it will load correctly after a few minutes, other times I need to relog to get it to launch correctly.
Yes I ticked “Clean Installation” at the time, didn’t help :sob:
I got 2.0.4 installed fine with clean installation. Maybe I didn’t do that before with 2.0.2 as I thought :thinking:
Handy to not have to use the controllers any more to bring up the Pimax Desktop UI.
I’m also trying Wide FOV mode. Nice improvement, guess about 116?
I presume with this profile it’s less binocular overlap to achieve it (do you have the %age to compare to Normal FOV?), so less stereo and a little more eyestrain. I’m sensitive to that, so I hope I can keep it on and still do 1-2 hour sessions. Will test and find out.
And curved mode for the Desktop UI to copy SteamVR desktop, much nicer :partying_face: EDIT: would be even better if it remembered that setting though :wink:
Another reoccurring problem @PimaxQuorra is that I keep getting the room setup pop up window, er, popping up on every launch.
It doesn’t matter if I fully complete the setup, or close the pop up and tick the ‘Don’t Remind Me Again’ box. Keeps happening. Is there a config value I can change if it’s failing to save my changes?
That’s strange. Let me report this bug to the dev team.
OK thanks. I did manage to stop this on 1.44.x but can’t remember how now. Didn’t involve any editing for sure. I’ll see if I can persuade it to stop here as well.
I’ve had the Pimax Dream Air (SLAM version) for a week now. I use it for sim racing.
What are the recommendations for installation – which version should I choose, PiPlay or EVO? Which works best with the SLAM?
Hi works
I am going to suggest joining the BextLevelSimgaming Discord. Great for getting info you are looking for with added pluses as well for Sim Gaming
Just make sure to read over terms of the server
