Pimax Customer Opinion Poll (MAS Side Pads)
I say it’s needed but have various widths available in foam and PU leather.
I’d like to know if we have to buy said Side pads who already own Pimax HMD with MAS? IMO they should be free for Pimax MAS owners. @PimaxQuorra
Why not just cut some Foam and apply velcro. As mentioned by a couple of ppl there fine with it as is.
This pad is very simple to cut one to desired thickness.
@PimaxQuorra @anon57422158
The hinges that attach the Pimax DAS to the HMD should have been angled in 25-45° or the enclosure angled in where the hinges are. A thicker plastic should of been used possibly the strengthen it.
Would these types of foam work? I’d have to cut to shapes of the existing ones or just wait and see what Pimax comes up with and if they want to rob us. Foams
Look what I just did to myself, they are fixed hinges that give the MAS total firmness, it seems that they are part of the HMD housing:
https://community.openmr.ai/t/rigid-hinges-prevents-wobble/37002/3
Any updates or has Pimax concluded it’s survey with the MAS Side Pads? @PimaxQuorra
A solid hinge setup might work like @Chumet has done.
