I’m actually more excited for the Crystal than the 12k at the moment. I know that my current PC can drive the resolution as I can maintain 90hz on the 8KX in my chosen application.
One area I didn’t see mentioned was whether we have options in term of frequency with the Crystal, I saw 160hz mentioned but will there be optional slower frequencies that can be selected, 90, 110, 144 etc.
Can you swap a low FOV lenses to a wide FOV or any size? Also, Pimax mentioned they allow 3rd parties to release their lenses…are there any 3rd party working on NEW lenses?
Since the crystal has XR2 inside, I was thinking again about my ideal software feature for the device in standalone mode.
Provided the electronics could work together this way, it would be the coolest software feature ever to be able to use a displayport to HDMI 2.1 cable to plug the HMD into any HDMI capable device, like say a blu ray player for playing disks or video games directly without streaming quality loss, without re encoding, just put a disc in and play it in a VR theater environment.
Watching a physical 3D blu ray in a VR theater rendered via the XR2 would make this thing an amazing home theater device.
I once hooked my Gear VR up to my 5.1 audio setup and watched a movie, and it was like having my own movie theater without taking up the space. Just a thought @SweViver@anon57422158
This will be a quite interessting Autumn - again . Playing lots of DCS and ACC, AM2 I often dial down the FOV so that I can get near those 90hz on the 8k. Really makes me wonder if the Crysal good be the better pick over the 12k for e.g. picking up the details in a DCS fight or the instruments over the large FOV on the 12k. Also Rendering all the goodnes on the 12k will be interesting. My 3090 more or less manages the 8kX - often the game engine beeing a bit outdated performance-technology wise (DCS’s know, like the vulcan stuff, and so on DLSS).
Cant wait to see through the lense shoots again
Oh is there more info on the panels used? Like backlight zones or such?
Agreed it will be very interesting, but at the same time I’m horrified by seeing that they use the same hinges still, those make the MAS wobble like crazy, and paying such a premium again for a HMD that is not up to par on the headstrap will be a no go for me.
That is my main worry here - they are now asking for price ranges which simply demand a certain level of product quality.
Perhaps there has been more going on behind the screens with the additional investments they secured and they turned around the company big style. But my gut feeling tells me that they at the core they won‘t change and that would lead me to expect devices which show serious potential on the one hand but frustrating shortcomings & sloppiness on the other.
That will be magnified even more with the complexity of the new devices - and the price point.
I wish Pimax good luck, because I would be happy to buy one of the devices if they could get really performing, polished products done. But it would have to perform pretty flawlessly for that money - I just don‘t see that happening, unfortunately.
Neither will the Crystal without changing the damn lenses to the High PPD version, I can’t stress enough that the Crystal still has only 2800 pixels. If you use the 42 PPD lenses you MUST get lower FOV.
42 PPD sounds nice. I used to change the vertical scan on our CRT monitors to have a higher dot pitch. That was great! I achieved a higher PPD there too, My screen was the size of a iphone, and my dad thought I was losing my mind…Clarity is not synonymous with PPD is all I’m saying. Pixels matter, GPUs matter. The rest is just a spec. If there was a pyramid built for clarity: The GPU would be the foundation, the CPU would be the material, and the HMD the middle portion and possibly the apex. Changing the lenses just doesn’t make a better viewing experience.
Taken to the extreme you could have a 2800 PPD HMD with a FOV of one degree. Anyone want that crap?
Well, this would be the point where PPI does become relevant…
IF the screen mount depth is the same for the 12k and Crystal models, and IF their respective display panels have similar PPI, and IF the Crystal models do not have a whole bespoke front part for the mounting of the lenses, but instead something of an adapter plate that goes where the 12k lens would normally go, and has the three screw holes that keeps each lens module in place; THEN it should indeed theoretically be possible to insert such an adapter plate into a 12k, for 110° 42PPD (EDIT: …for occasions where that is desired), utilising a portion of the 12k screens…
I wonder though, I remember that HTC factory calibrates each headset’s lenses and stores the distortion/mura profile in the headset. This can be found in the lighthouse.db file you can dump from the headset.
I guess Pimax does not need to do this as the manufacturing variance between lenses is near 0.
Did they mention how much the extra lenses might cost?
I think the two lenses have a different missions. They’re for different use cases. The 42 PPD lens is probably not intended for VR immersion and gaming. I think it’s for more utilitarian uses such as 3D design.
The 35 PPD lens is the one that comes with it by default, and that is probably the one that the vast majority of customers will use. That one is intended for gaming and general VR use. And probably most customers will never actually use the ability to change out the lenses.
One reason I’ll mention for this is that users of the Aero at ~35 PPD often mention that it’s actually too much PPD for most modern VR games. It shows lack of texture resolution and flaws that weren’t visible at the more typical PPDs that other VR headsets could achieve. Presumably this just gets worse at 42 PPD. The higher resolving power doesn’t get you anything if there’s no more detail to resolve.
