Pimax Blue Coating
Hey all,
Does anyone know what kind of product the blue protection layer of the new pimax headset is?
I’m looking for someway to re-enforce my 204 series 5k before it starts to crack.
you might try something like that :smile:
Unfortunately covering the material will interfere with tracking. It was stated in another post awhile ago that the RE edition is a completely different compound for the entire plastic not just a coating. The silicon skin with cutouts may be the only way to " cover it up".
You should consider the silicon sleeve if you have concerns.
PS: If you have a Backer Box coming you will be receiving one.
That sucks to hear. We’re stuck with these brittle plastic headsets until they fall apart I guess. I already have the silicon sleeve.
As that isn’t exactly an acceptable answer, I’m likely going use the sleeve as a masking template and then epoxy coat the plastic for re-enforcement.
Obviously thickness plays a role, but I’d look for an epoxy with strong optical transmission properties at infared wavelengths. Then you may not have to be so careful. I’d still be avoiding the holes if I could :stuck_out_tongue:
using the sleeve as template sounds like a good idea, i was thinking of just glueing in permanently to the headset but your idea sounds less permanent.
I am not sure how much you are willing to spend but you can get the housing replaced with an RE by this company:
https://community.openmr.ai/t/re-housing-in-stock/29694
I am sure I have to skills to change over the housing or case or whatever it’s called. It wouldn’t be that difficult. Can’t cost Pimax much to post out a new housing to those who can do it themselves or can get someone to do it.
