# Pimax Artisan with Vive Pro strap
**URL:** <https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721>\
**Category:** P2: Artisan\
**Created:** [May 10, 2020, 6:18am UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721 "2020-05-10T06:18:08Z")\
**Posts on this page:** 20\
**Page:** 1
<div class="post-metadata">
**Author:** ![ShawnMayer](https://forum.openmr.com/letter_avatar_proxy/v4/letter/s/3ab097/32.png) [@ShawnMayer](https://forum.openmr.com/u/ShawnMayer)\
**Post date:** [May 10, 2020, 6:18am UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/1 "2020-05-10T06:18:08Z")
</div>
![image](https://community.openmr.com/uploads/default/original/3X/3/a/3a995b3f65e5c4c9a22457d4155f1c8004143534.jpeg)
I complete my Pimax Artisan with Vive Pro Strap using this adapter and koss ksc75 headset.
[https://community.openmr.ai/t/mathias-delahaye-pimax-vive-pro-adapter/27208?u=shawnmayer](https://community.openmr.ai/t/mathias-delahaye-pimax-vive-pro-adapter/27208?u=shawnmayer)
This is really comfort and koss ksc75 sound is really great.
Vive Pro strap : 45$
Koss KSC75 : 20$
**Author:** ![Marco](https://forum.openmr.com/letter_avatar_proxy/v4/letter/m/a698b9/32.png) [@Marco](https://forum.openmr.com/u/Marco)\
**Post date:** [May 10, 2020, 10:39am UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/2 "2020-05-10T10:39:52Z")
</div>
Hi, but where did you buy a Vive Pro strap for 45$?
**Post date:** [May 10, 2020, 10:47am UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/3 "2020-05-10T10:47:27Z")
</div>
That is awesome! But agreed where you score the Vive pro strap? Look forward to seeing a side by side of the MAS when available. 🍻🕶🖖✨
**Post date:** [May 10, 2020, 11:09am UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/4 "2020-05-10T11:09:02Z")
</div>
Here it is. But you’d better confirm stock before order.
[https://www.mobile-part.com/htc-vive-pro-mount-cradle-all-assy-74h03422-10m-p0400.html](https://www.mobile-part.com/htc-vive-pro-mount-cradle-all-assy-74h03422-10m-p0400.html)
**Author:** ![twack3r](https://forum.openmr.com/letter_avatar_proxy/v4/letter/t/c5a1d2/32.png) [@twack3r](https://forum.openmr.com/u/twack3r)\
**Post date:** [May 10, 2020, 11:51am UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/5 "2020-05-10T11:51:56Z")
</div>
Where did you get the ksc75 assembly for the Vive Pro strap from?
Just ordered the strap and a 3D print for the adapters, will be interesting on my 5K+ with the CK.
**Post date:** [May 10, 2020, 12:09pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/6 "2020-05-10T12:09:19Z")
</div>
> **[Rift S Koss Porta Pro and Koss KSC75 better mount by exp300](https://www.thingiverse.com/thing:4337636)**
> Combined two of JorgTheElder's designs. All credit goes to him. I loved this rubberband loaded design but found that the headphone connector from this design worked much better with my Koss KSC75.
> Should work for both Koss KSC75 and the...
I modded this thing my self. and just attached by 3m tape.
And if you want to try this mod, you have to get screw. mobile-parts doesn’t sent screw to me.
**Post date:** [May 10, 2020, 12:34pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/7 "2020-05-10T12:34:12Z")
</div>
This is modded stl file by me. (Sorry for not as good modeling).
If you need to adjust some parts, using blend file easily.
STL
> **[CapEarphoneF2.stl](https://drive.google.com/file/d/1qsAwwUhr0trx3l23gIEvPZtmiBwaiFWI/view?usp=drive_open)**
> Google Drive file.
Blender
> **[Final.blend](https://drive.google.com/file/d/1BxWBnfkpj62XvcPIHl4YvKhozhQm2xO7/view?usp=drive_open)**
> Google Drive file.
**Post date:** [May 10, 2020, 1:01pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/8 "2020-05-10T13:01:32Z")
</div>
Fantatsic, thanks!
All parts are ordered, will give feedback once assembled.
**Author:** ![mirage335](https://forum.openmr.com/user_avatar/forum.openmr.com/mirage335/32/15861_2.png) [@mirage335](https://forum.openmr.com/u/mirage335)\
**Post date:** [May 10, 2020, 3:41pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/9 "2020-05-10T15:41:55Z")
</div>
Would be great to have an alternative source. Their website is at best extremely difficult to use.
**Author:** ![JoCool](https://forum.openmr.com/user_avatar/forum.openmr.com/jocool/32/22953_2.png) [@JoCool](https://forum.openmr.com/u/JoCool)\
**Post date:** [May 10, 2020, 7:17pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/10 "2020-05-10T19:17:06Z")
</div>
Do the HTC Vive Pro Headphones work with the Pimax’ USB-C port?
This is a very interesting option.
**Author:** ![Virtualmisterl](https://forum.openmr.com/user_avatar/forum.openmr.com/virtualmisterl/32/17057_2.png) [@Virtualmisterl](https://forum.openmr.com/u/Virtualmisterl)\
**Post date:** [May 10, 2020, 7:49pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/11 "2020-05-10T19:49:52Z")
</div>
The HTC vive pro headphones are wired into the board via 2x small 4 pin connectors.
Best bet would be to rewire them to a 3.5mm audio jack
**Post date:** [May 10, 2020, 8:00pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/12 "2020-05-10T20:00:27Z")
</div>
Hi, thanks for the response.
Oh okay thanks for the information
**Author:** ![Skidrow](https://forum.openmr.com/letter_avatar_proxy/v4/letter/s/839c29/32.png) [@Skidrow](https://forum.openmr.com/u/Skidrow)\
**Post date:** [May 10, 2020, 8:26pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/13 "2020-05-10T20:26:21Z")
</div>
Feels abit fishy, HTC dont sell there Prostrap at all and charge 100 for DAS, this one is without speakers so wounder if it simple someone copied HTC Prostrap without ok from HTC 🙂
**Post date:** [May 10, 2020, 8:31pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/14 "2020-05-10T20:31:10Z")
</div>
Hard to say but with HTC discontinuing the pro. Might be left over stock.
Either way this is good for folks waiting on the clone for their headset.
**Post date:** [May 25, 2020, 12:03pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/15 "2020-05-25T12:03:39Z")
</div>
Just a quick heads up for anyone considering doing the same mod:
It‘s been 15 days since I ordered the Pro headstrap from [mobile-Part.com](http://mobile-Part.com) and I‘m yet to receive it. Last tracking status ist from May 16th leaving China, no news since.
I have received all the 3D printed parts and will update on assembly once and if I get the headstrap.
**Post date:** [May 25, 2020, 12:46pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/16 "2020-05-25T12:46:58Z")
</div>
You’ll need to this one.
And also screw. I removed the screw from the vibe and used it.
> **[001 (3).stl](https://drive.google.com/file/d/1PJyJZvD4cdfkZ6MUnG7v6oCI6WnIowLP/view?usp=drive_open)**
> Google Drive file.
**Post date:** [May 25, 2020, 2:05pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/17 "2020-05-25T14:05:07Z")
</div>
OK, can you reference what sort of screw would be needed?
I was under the impression that the .stl files you had previously shared were all that was required.
I will order two of the most recent .stl file you have linked but it would be a shame, if 2 screws missing would render the entire project defunct.
**Post date:** [May 25, 2020, 3:09pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/18 "2020-05-25T15:09:06Z")
</div>
I can’t found about screw’s info.
So I just used screw from vive that no longer in use. If you need picture, I’ll take photo and upload when I can.
**Post date:** [May 25, 2020, 3:40pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/19 "2020-05-25T15:40:15Z")
</div>
Are we talking OG Vive or Vive Pro?
I have an OG Vive in my spare parts.
**Post date:** [May 25, 2020, 3:54pm UTC](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721/20 "2020-05-25T15:54:42Z")
</div>
It’s an original Vive screw same as Vive pro.
[Next page](https://forum.openmr.com/t/pimax-artisan-with-vive-pro-strap/27721.md?page=2)
