portal
1
Hello,
I noticed you all have a check box to enable/disable base stations on the pitool. I was wondering:
- Do you have a unity plugin where I can enable/disable the need for light houses within my program?
- If not, could you all share the code that is run when I check the enable/disable light houses box?
Thank you!
Best,
Kyle
Hi @Sean.Huang can you help him with this request & add him to Developers group.
Portal there is a Unity\Unreal sdk in the Banner topic that may help.
This does not work?
Did you test Pimax as XR device (OpenVR for SteamVR family)? If it works, you don’t need any plugins.
portal
4
Unfortunately this doesn’t work for my use case
Unfortunately, my Pimax headset is still somewhere in production astral, so I can’t make any tests.
