Guys, how setup only 1 LH with Pimax ? I’m usually using 2 LHs but I want give/loan one of my LH to my friend for test. Right now I have chanel “b” and “c” active , changed to “a” and powered on one base station but Pimax is not tracking and base station is blinking in Pitool.
Kind of noob question probably but I never tested myself Pimax with 1 LH.
Use channel B.
The station must be at least 1.5m, better 2m away.
Tryied. Pimax is not tracking. Meybe becouse he got used to 2 LHs system
No, I can easily switch from both to one.
However, I also have a distance of 3m.
Do you have alsu use channel c?
Agreed, I have a single v1 LH and works fine with B.
Small room, but initial tracking is fine once you get 2m away, and then you can move closer in again.
Its not problem with room , distance and so on… Pimax is tracking only when 2 of my LHs are turned on and communicating each other. Tried different chanels and distances already.
Try a pc reboot with only 1 Station… maybe
I have solved problem - thanks to all involved
