Awesome was Sean able to ascertain why the Review units & your 8k unaffected?
No idea, I just informed him about that this last procedure worked (we tried a few), and sent him the log files. (We communicate through email atm) Lets see what he responds. I also informed him about this thread, and the fact that others have the same problem.
I linked your post in @Davebobmanās compilation of issues with potential solutions.
In the Banner topic itās in tge 5k+ 8k Directory link.
Great! Lets see what Sean says
I have the same issue.
Currently waiting on a Teamviewer session, should be happening real soon.
If the Teamviewer session doesnāt happen I will try this fix.
Thanks for posting this.
Will update if/when fixed.
Cheers
Neil.
Happy to report that @Sean.Huang has worked some wizardry on my Teamviewer
session and my headset is now tracking.
Untested on any games yet as have to do tea.
Will test a little later.
Canāt wait.
Thanks @Sean.Huang you are a legend.
Cheers
Neil.
Iād say thatās the same as just deleting that lighthouse config file and then reboot pc. I think he did the other steps just to see if deleting that config file fixed the problem (restarting the service is the same thing as restarting the PC, at least, for the HMD).
Deleting those config files and rebooting PC did not help for some weird reason. We tried that right before trying this. Seems that restarting the services in the same session does something more⦠
Hmm thatās odd ⦠The services are started when windows finishes booting, exactly like when you restart them manually. Not sure why the result would be different but I guess that in theory they could do dump config to disk when closing windows, in which case just deleting the file alone wouldnāt help. But that would be weird.
Anyway glad it works now.
Here is what works for me: When HMD loses tracking and will not be found by lighthouses, delete lighthouse directory and restart service as described above. THEN, move HMD out of view of lighthouses completely. THEN bring HMD back into view of lighthouses. Tried it several times and was able to get to work every time.
Thanks. But does it happen often? I have never seen this problem with the review units, nor the m1⦠
Not really. I never lose tracking once acquired. If PiServer canāt find the HMD at start-up it is usually enough to just move it out of sight of the lighthouses for 10 seconds and then back in view.
You know, this is the good thing about being backer 6XXX : fortunatly all these āearly backerā problems will be solved by the time (march 2019 ?) we will get our Headset
That almost sounds like M1 had better tracking signal due to thinner plastic. Not sure, but this might explain it.
I have created a batch file that will go through this process (except restarting your PC).
It is untested (I donāt have PiTool or my headset) so I would appreciate if @Sjef and/or some other code monkeys would take a look at it.
EDIT: It is extremely ugly but heavily commented. Who knew that commenting in a batch file would look that bad.
EDIT Here are the contents of the batch file (in case the Dropbox link gets broken at some point). To make your own batch file just copy the contents into a text file and change the extension from ā.txtā to ā.batā.
REM Everything after REM is a comment.
REM How to "comment-out" (add comment) in a batch/cmd? - Stack OverflowREM Variables in case of future changes
REM cmd - Defining and using a variable in batch file - Stack Overflow
REM What are PATH and other environment variables, and how can I set or use them? - Super Userset LighthouseConfigLocation=āC:\Users\%USERPROFILE%\AppData\Local\Pimax\runtime\config\lighthouseā
set service1=āPiservicelauncherā
set service2=āPiServiceā
set Service2Location=āC:\Program Files\Pimax\RuntimeāREM This deletes Pimaxās lighthouse configuration files
REM windows - How to delete all files and folders in a folder by cmd call - Stack Overflowdel /q %LighthouseConfigLocation%*
for /d %%x in (%LighthouseConfigLocation%*) do @rd /s /q ā%%xāREM This restarts service1
REM NET.EXE: Start/stop/restart any Windows Service from the command line | The Core Technologies Blognet stop %service1%
net start %service1%REM This restarts service2
net stop %service1%
REM net start %service1% &REM This command will restart the service.
%Service2Location%%service2%.exe &REM This command will restart the service from a specified location.
Thanks! Very confusing though in my case: moving HMD out of view and then back into view worked for me, but so far only once. Tried to repeat the action after restarting the PC (head tracking was lost again after that of course) several times and couldnāt repeat the initial outcome.
Thank you for your advices,
For two weeks I was travelling and did not have acces to my pimax.
I have purchased and installed an additional USB card (Inateck) installed PiToolSetup_1.0.1.84, but my pimax is still stuck in black (black screen, black led), I was not able to turn it back on.
I have tried to set the pimax headset in dfu mode as described by @SweViver on his 1st november video:
The led color did not change (still black) but I still tried the dos command only to get the message ā0 Device(s) found. Plug your DFU Device !ā
I tried connecting the pimax to a second computer but it is not detected.
I have once again measured the voltage out of the power brick. It is about 12V.
I have reached out to pimax support and will wait for their answer.
Have you heard back from Pimax support? I havenāt. I sent them an e-mail on Friday.
@Pimax-Support @Sean.Huang @Matthew.Xu the 2 gentlemen sbove need your assistance.
Dear @Ronanbuzz, Dear @SweViver,
Iām very sorry for the inconvenience.
I need to trouble you, please submit your question to the service desk.
We will transfer your questions to our technical engineers, who will help you solve them as soon as possible.
Thank you very much.
