# Nasal FoV of Pimax and Quest
**URL:** <https://forum.openmr.com/t/nasal-fov-of-pimax-and-quest/39930>\
**Category:** General discussion\
**Tags:** oculus-quest, fov, pimax-8k\
**Created:** [December 5, 2022, 3:13am UTC](https://forum.openmr.com/t/nasal-fov-of-pimax-and-quest/39930 "2022-12-05T03:13:30Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![LionBrooks](https://forum.openmr.com/letter_avatar_proxy/v4/letter/l/ba9def/32.png) [@LionBrooks](https://forum.openmr.com/u/LionBrooks)\
**Post date:** [December 5, 2022, 3:13am UTC](https://forum.openmr.com/t/nasal-fov-of-pimax-and-quest/39930/1 "2022-12-05T03:13:30Z")
</div>
Hi, I barely saw discussion about nasal fov but it has bothered me for a long time.
On the nasal side, I can feel back blurry edges in my FoV. I did a comparison between my pimax 8k and quest pro, and found it is severer in pimax (might due to canted design).
Also, when I press the headset harder on my face (smaller eye relief) or my vergence distance is larger, those black edeges are less obvious. I suppose this is caused by insufficient nasal side of fov?
Although it is not 100% unaccpetable, it is bit of annoying. Anyone has the same experience? And any thoughts about what will be a good nasal side fov?
**Post date:** [December 5, 2022, 6:13am UTC](https://forum.openmr.com/t/nasal-fov-of-pimax-and-quest/39930/2 "2022-12-05T06:13:51Z")
</div>
Hello,
Have the comfort kit installed on the headset?
This will improve your wearing experience and make those edges less visible / completely erased.
Regards.
**Post date:** [December 6, 2022, 1:11am UTC](https://forum.openmr.com/t/nasal-fov-of-pimax-and-quest/39930/3 "2022-12-06T01:11:11Z")
</div>
Thanks for the advice. The comfort kit did provide better wearing experience.
But I feel it also increases your eye relief distance and lead to even smaller FoV. So the ‘edges’ are more clear.
**Post date:** [December 7, 2022, 3:18am UTC](https://forum.openmr.com/t/nasal-fov-of-pimax-and-quest/39930/4 "2022-12-07T03:18:04Z")
</div>
Hello,
You may try to adjust the strap till a crisp image is shown on the headset.
**Post date:** [February 5, 2023, 3:18am UTC](https://forum.openmr.com/t/nasal-fov-of-pimax-and-quest/39930/5 "2023-02-05T03:18:45Z")
</div>
