Could we please get a sensitivity slider or vibration damper buttun because a buttkicker causes the headtracking to be bad and a motion platform like dofreality causes bad head tracking too just not as bad as the buttkicker. The motion compensation works great but the vibrations cause it to be unusable. Please add a way that will allow vibrations but not affect the tracking. I use a pillow between my controller (used form motion tracking) and my motion platform frame, but it does not eliminate the vibration.
Using DOF Reality as a motion platform? Then I strongly recommend to use a witmotion sensor and the motion compensation build into sim racing studio to be honest. Using thsi myself for many years now also in combination with the super mOled (previously the 50ppd) and never had any issues at all
Let me forward this to our dev team, and I’ll also ask the OXRMC dev team for some suggestions.
witmotion only works with a two or three dof platform. I have a six dof platform
I have dofreality h4 and vive tracker for motion compensation. Working perfectly
Yes you are right, my bad
