Correct, pitool works the same than oculus rift SS.
OK. Then it appears that you could set either of them to 1.0 and then just vary the other setting until you reach optimum performance.
I made some important discoveries about reported resolutions!
https://community.openmr.ai/t/psa-pitool-render-resolutions-are-not-linear/12079
Posted the results here, please check it out and replicate on your side if you have a chance.
Correct. I suggest adjusting SteamVR supersampling as that needs no reboot plus you have a per app setting there.
Answered, added to Reddit Pimax Wiki.
