Using SPS in Iracing I have a strange and annoying visual effect: when I turn my head from one side to the other, the image seems to zoom in and out, causing eye strain. Does anyone else have the same problem? (With my Vive Pro SPS works very well), so I think the problem is the Pitool software.
The problem remains either with PP activated or not.
There is s topic on iracing. I believe the rec is sps off & pp off.
Did you find solution?, I’m having the same problem and cannot find solution to use SPS with 1080ti R3600 and Pimax5+
