Index Controllers appear far away
Nope not if your problem is not solved :blush:
is it chaperone_info.vrchap? @MrAhlefeld
When I switched from 5k+ to 8kx I had tracking, but wrong positioned. I had to uninstall steam vr and delete all tracks of it, and then also uninstall pitool and all tracks of it ( there are several of booth, ask google).
After that with new install it is ok now.
Ps; I tried to uninstall, clear leftovers, restart and again install separately pitol, and then steam vr - that didn’t help.
Here’s the Quick and dirty (no not really) :crazy_face: (if PiTool uninstaller did remove all it’s remnants alot of manual work would not be needed, im sure some steps could be skipped but hey at least it’s a Clean install)
  1. Uninstall Pitool via Add or remove programs
  2. Delete C:\ProgramData\pimax
  3. Delete C:\Program Files\pimax
  4. Delete C:\Users\ YourUserHere\AppData\Local\Pimax
  5. Delete C:\Users\ YourUserHere\AppData\Local\PiTool
  6. Delete C:\Users\ YourUserHere\AppData\LocalLow\Pimax
  7. Delete C:\Users\ YourUserHere\AppData\Roaming\PiTool
  8. Delete C:\Steam\config\chaperone_info.vrchap (or what ever drive your Steam installation is on)
  9. Install newest PiTool
  10. Install (if this is your preference Pimax VR Experience)
  11. Run PiTool Room Setup
  12. Run SteamVR Room Setup
And your done.
To answer your question.
There are 2 chaperone_info.vrchap files.
First is in C:\ProgramData\pimax\runtime\chaperone_info.vrchap (you deleted this in Step 2)
Second is in your Steam client install folder ā€œmine is inā€ D:\Steam\config\chaperone_info.vrchap
Worked for me this morning.
Cheers
Il give this a shot soon, thanks!
thank you for this @MrAhlefeld, unfortunately even all this didnt solve my problem. Thank you for trying though
That’s odd, might you have Steam installed somewhere else or have had it installed somewhere else ?
Try searching for chaperone_info.vrchap on all your disks.
No I found it and deleted it, it just didn’t work. Pimax is saying it’s a hardware issue and started the rma process.
Guys I think that booth steamvr and pitool have their own copies of vr universe (room, positioning, angles, controllers…), and booth must be terminated, uninstalled, and all their leftovers erased AT SAME TIME!!! Each of them has a copy of universe, and make your controllers floating - that will be copied on reinstalled program also.
Try this, it was successful with my pc.
That’s what I wrote :wink: in my ā€œguideā€
I do not see uninstall steamvr? Just erasing some steamvr files
https://developer.valvesoftware.com/wiki/SteamVR/chaperone_info.vrchap
it lives in .\Steam\config
and for some odd reason there is a derived copy of it in C:\ProgramData\pimax\runtime
(that would be number 2 & 8 in my ā€œguideā€ that deleted that file :wink:
/Martin
