# Improving VR FPS (Pimax 8K X) - which componet should I swap?
**URL:** <https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461>\
**Category:** General discussion\
**Tags:** pimax-8k, discussion\
**Created:** [March 21, 2021, 9:56pm UTC](https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461 "2021-03-21T21:56:45Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![pascal314](https://forum.openmr.com/letter_avatar_proxy/v4/letter/p/3be4f8/32.png) [@pascal314](https://forum.openmr.com/u/pascal314)\
**Post date:** [March 21, 2021, 9:56pm UTC](https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461/1 "2021-03-21T21:56:45Z")
</div>
Hello Guys,
I need your help, I want better FPS in VR (Elite Dangerous) and I am not sure which componet of my pc I should upgrade (Pimax 8K X).
My specs:
Ryzen 5 2600X
16 GB 2160 Mhz Ram
Asus X370 Motherboard
MSI 3090 Ventus
Be quiet 850 Watt PSU
cooler Master 120 mm cpu water cooling
500 GB SSD
I think most likely I should swap the 2600X to a 5600X, even though I love my 2600X, it did not ever had a defect since 2018.
The 5600X should gives more stable FPS with very likely reduced fps drops (stutter)
Also my RAM is not the fastest one, maybe I should swapping to a 3200 Mhz RAM?
How big would be the improvement then for upgrading the RAM?
Any suggestions (and similar experiences of upgrading) are highly appreciated, thanks!
**Author:** ![Butosai](https://forum.openmr.com/letter_avatar_proxy/v4/letter/b/b19c9b/32.png) [@Butosai](https://forum.openmr.com/u/Butosai)\
**Post date:** [March 21, 2021, 10:11pm UTC](https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461/2 "2021-03-21T22:11:58Z")
</div>
cpu for suuuuuuuuuure the gpu must be getting hardcore bottlenecked. upgrading the cpu means u gotta upgrade the motherboard too
**Author:** ![neal\_white\_iii](https://forum.openmr.com/user_avatar/forum.openmr.com/neal_white_iii/32/3038_2.png) [@neal\_white\_iii](https://forum.openmr.com/u/neal_white_iii)\
**Post date:** [March 21, 2021, 10:35pm UTC](https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461/3 "2021-03-21T22:35:12Z")
</div>
Unfortunately, Elite D requires parallel projection, which adds ~30% additional overhead to your GPU.
While faster RAM will improve your system, generally speaking, it’s only going to make a minor difference, say ~2-3% FPS increase at best. It looks like you need a CPU upgrade. Make sure your power supply is sufficient for your new CPU, because water-cooling and a 3090 eat a lot of power.
If that’s out of your budget, try reducing your FOV. Currently, I only have a 2080, so I’m using Small FOV to play ED. I just pretend my space helmet is blocking the edges of my view.
**Post date:** [March 21, 2021, 10:44pm UTC](https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461/4 "2021-03-21T22:44:25Z")
</div>
I would agree with Others. Upgrade CPU & Ram.
3200 should be decent. If on a bit of a budget and not wanting to upgrade mobo atm look into a 3600x or 3700x. This will also give time to see how Amd corrects some of the usb issues reported on the 550 and 570 chipsets.
**Post date:** [March 23, 2021, 12:31pm UTC](https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461/5 "2021-03-23T12:31:18Z")
</div>
Thank you for all your suggestions!
Ok then I will upgrade my cpu to a 5600X and also my RAM, maybe also my mobo.
**Author:** ![Deathwalker316](https://forum.openmr.com/user_avatar/forum.openmr.com/deathwalker316/32/22421_2.png) [@Deathwalker316](https://forum.openmr.com/u/Deathwalker316)\
**Post date:** [May 13, 2021, 10:44pm UTC](https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461/6 "2021-05-13T22:44:09Z")
</div>
Throwing in with the others. CPU, RAM.
Will throw in one suggestion: Get an M2 SSD and put all your VR stuff on there. If your new board will support 2, put your OS on one and your VR/Game stuff on the other.
SSD is fast, but M2 will give you that extra bit of speed while loading.
**Post date:** [July 12, 2021, 10:44pm UTC](https://forum.openmr.com/t/improving-vr-fps-pimax-8k-x-which-componet-should-i-swap/35461/7 "2021-07-12T22:44:15Z")
</div>
Closed on July 12, 2021, 10:44pm UTC
