I haven’t updated USB port yet, I’m using usb 3.0 which is not on motherboard.
I putted cable into PCI-E USB port card which I’d installed on motherboard.
I didn’t connect to Original USB port on motherboard because it’s continuously disconnecting when I use it with my Pimax HMD. other device works fine except with Pimax.
Mine is only working on pic-e card, strongly recommend you to update you usb drivers
Also in device manager i have power management disabled for all usb devices.
No issue with sound soo far
Hope it helps.
Hi Lathander, same problem for me. I tried USB 2.0 and USB 3.0. Hope support help me tomorrow. This is really strange problem that this affect the hmd !!! Bad Drivers or something like that…
It’s a USB controller issue, 100%. If you’re using a pcie usb controller, try installing the drivers for your specific controller. I had this issue with my inateck usb controller before installing the drivers (and also with my motherboard usb ports which were connected to an asmedia usb controller, which is why I bought the inateck controller in the first place).
