# HMD DP permanently 10600 error after firmware update in PiTool V1.0.1.270
**URL:** <https://forum.openmr.com/t/hmd-dp-permanently-10600-error-after-firmware-update-in-pitool-v1-0-1-270/35654>\
**Category:** Report Bugs\
**Created:** [March 29, 2021, 6:27pm UTC](https://forum.openmr.com/t/hmd-dp-permanently-10600-error-after-firmware-update-in-pitool-v1-0-1-270/35654 "2021-03-29T18:27:44Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![Siberdt](https://forum.openmr.com/user_avatar/forum.openmr.com/siberdt/32/1618_2.png) [@Siberdt](https://forum.openmr.com/u/Siberdt)\
**Post date:** [March 29, 2021, 6:27pm UTC](https://forum.openmr.com/t/hmd-dp-permanently-10600-error-after-firmware-update-in-pitool-v1-0-1-270/35654/1 "2021-03-29T18:27:44Z")
</div>
My 8K was alive right until I installed PiTool V1.0.1.270 and firmware update succeed.
Now I have permanent **Diagose Error 10600** with USB or both USB and DP Disconnected
No changes after switching port, rebootings, restarting servicers etc.
Every experience with this headset is a pure pain for me ☹
**Author:** ![tonka](https://forum.openmr.com/letter_avatar_proxy/v4/letter/t/9f8e36/32.png) [@tonka](https://forum.openmr.com/u/tonka)\
**Post date:** [March 29, 2021, 10:25pm UTC](https://forum.openmr.com/t/hmd-dp-permanently-10600-error-after-firmware-update-in-pitool-v1-0-1-270/35654/2 "2021-03-29T22:25:41Z")
</div>
I had exactly the same problem with my 8K+ and in the end I gave up and reinstalled Pitool 268 keeping the same firmware and the headset was working fine again.
**Author:** ![Finn](https://forum.openmr.com/letter_avatar_proxy/v4/letter/f/e68b1a/32.png) [@Finn](https://forum.openmr.com/u/Finn)\
**Post date:** [March 30, 2021, 4:39am UTC](https://forum.openmr.com/t/hmd-dp-permanently-10600-error-after-firmware-update-in-pitool-v1-0-1-270/35654/3 "2021-03-30T04:39:00Z")
</div>
@Siberdt- I had the same issue. Here’s what worked for me. Using task manager, turn off all Pimax processes.
Then go to C: users\your name\AppData\local\Pimax and delete pi\_device. Then do a DFU install again. I can’t remember if any of the other files in your appdata\local\Pimax folder need to be deleted, but for sure get rid ot the pi\_device text file.
Contact support too. If you open a ticket they can send you debug help.
Your HMD is NOT permanently bricked, don’t worry!
finn
**Post date:** [March 30, 2021, 5:20am UTC](https://forum.openmr.com/t/hmd-dp-permanently-10600-error-after-firmware-update-in-pitool-v1-0-1-270/35654/4 "2021-03-30T05:20:41Z")
</div>
Hello,
We suggest you to have the 268 Ver of Pitool and Firmware，so you could use the device while waiting for the solution.
Then please file a ticket at our support, and allow our technician to provide the assistance.
Sincerely.
**Post date:** [March 30, 2021, 10:15am UTC](https://forum.openmr.com/t/hmd-dp-permanently-10600-error-after-firmware-update-in-pitool-v1-0-1-270/35654/5 "2021-03-30T10:15:00Z")
</div>
Thanks for your answer, but where can I get the previous firmvare **.dfu** file?
**Post date:** [March 30, 2021, 10:16am UTC](https://forum.openmr.com/t/hmd-dp-permanently-10600-error-after-firmware-update-in-pitool-v1-0-1-270/35654/6 "2021-03-30T10:16:50Z")
</div>
Hello,
For non 8KX, you can download via [264 Firmware Update](https://pitool.oss-accelerate.aliyuncs.com/R264.dfu)
Sincerely.
