I tried using Potato View to give myself a bit more headroom for sampling but for some reason it made the game’s contrast get overblown. Bright scenes became way to bright to the point where you couldn’t see some things. Anyone else have this issue? It went away when I put it back on Small FOV.
yes i have this patch sinds saturday,its a shader patch and helps with stuttering.
But i realy hope they give us an option to disable AA (i think there is somekind of TAA applied)And if there is somekind off dynamic resolution to turn that off as well.
And some more patches for the vr janky stuff…
But it is realy fun in vr(even with the bad vr controls) i do like it alot more then my first impressions…
This is good news. There is a chance they will fix this because I have a feeling that they are going to want to put this on PSVR2. As it stands right now I dont know if Sony is going to give this their seal of approval as it is now.
And they need to have controls worked out by then. I suspect that this may partially be the reason we got a port to begin with.
Does anyone have the problem with no audio in the headset while playing Hitman3 my computers audio is working fine and when I start the game in desktop mode everything works fine if I choose system or stereo in sound settings but when I start up in vr the setting is locked to headphones and there is no audio very annoying
I have experienced several titles (usually UnrealEngine-based ones), which launch without hogging window focus, and for some reason remain silent until I alt-tab my way to them myself, but I imagine that can’t be it…
I had a strange problem when Wolfenstein iirc came out. I had to disable audio devices not in use; even though the game gave you a direct option in it’s own settings to choose which one to use.
With it defaulting to Headphones it might not be using the Usb audio device that the headset uses. You may need to see if Hitman has an option ig to choose preferred audio device or a settings file.
EDiT
This reddit post is Quest but the described fix sounds like it will work.
Thanks for you’re suggestions but I also found the Reddit fix but my windows sound is working just fine the game just does not see my usb audio device as default for headphones I already tried to manually choose the audio devices in steam vr but I bought this game a year ago through epic games so maybe that’s an issue I did not know the vr part was PS exclusive I was so disappointed but I already put in 2 ticket request at the so called hitman 3 support website lots of hitman but not a lot of support it’s been like 3 days now but there probably to busy with fixing problems so I’ll just have to wait and see if they are going to help because it’s definitely a problem with there game al my other games work absolutely fine
