# Help Pimax 5k Plus (Yellow Light after Update)
**URL:** <https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039>\
**Category:** P2: 5k(+/XR)\
**Created:** [July 27, 2022, 1:58am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039 "2022-07-27T01:58:17Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![Isabel](https://forum.openmr.com/letter_avatar_proxy/v4/letter/i/977dab/32.png) [@Isabel](https://forum.openmr.com/u/Isabel)\
**Post date:** [July 27, 2022, 1:58am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039/1 "2022-07-27T01:58:17Z")
</div>
Hi, I’m Isabel and I recently bought some used Pimax 5K+ plus, I’ve been using and testing them for a while.
Pitool had an update available, I think it was 269 and after updating the Pimax 5k+ it no longer When turning on, it stays with a flashing yellow light.
It tells me that it does not detect the HDMI/DP disconnected.
This has happened after the update, I have tried to find a way to solve the problem, I have found some files, which are to update the Pimax in DFU mode, but I have not had any luck with this, the Pimax is programmed but it returns to light yellow.
The files used were P2\_D262.dfu, 260, 264 and others, but the light keeps flashing yellow
Please, Pimax Technicians, ¿can you help me with this problem?, thanks
PimaxLog:
```auto
########HMD connected at 2022-07-27 01:16:51########
product name: Pimax P2C
bootloader Ver: R132
firmware Ver: R2.1.255.269 - id_e977219_20201112
board serial: xxxxxxxxxx0083
module serial: xxxxxxxxxx0083
product serial: xxxxxxxxxx0083
work mode: normal
panel type: panel_b5x
BoardFCT result: 0x00020000
HmdFCT result: 5000
release flag: 6000
brainwarp flag: False
panel left flick level: 0a
panel right flick level: 0a
panel left bright level: 45
panel right bright level: 45
last display state : STATE_NONE
current display state : STATE_NONE
EE Flash selftest result: 0
Current Calibrate Flag : False
 0x08004000: 08 04 FF 00 00 02 00 0B 04 00 46 46 46 46 FE 01 00 02 FE 01 00 01 01 10 FF 32 30 32 36 30 34 38
 0x08004020: 34 39 30 30 30 38 33 00 00 FE 01 00 02 02 10 FF 32 30 32 36 30 34 38 34 39 30 30 30 38 33 00 00
 0x08004040: 0A 04 00 31 30 30 30 FE 01 00 03 03 10 FF 32 30 32 36 30 30 38 34 39 30 30 30 38 33 00 00 0C 01
 0x08004060: FF 00 0A 04 FF 35 30 30 30 FE 01 FF 00 0B 04 FF 36 30 30 30 FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080040A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080040C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080040E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080041A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080041C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080041E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004200: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004220: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004240: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004260: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004280: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080042A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080042C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080042E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004300: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004320: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004340: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004360: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004380: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080043A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080043C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080043E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004400: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004420: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004440: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004460: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004480: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080044A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080044C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080044E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004500: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004520: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004540: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004560: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004580: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080045A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080045C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080045E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004600: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004620: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004640: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004660: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004680: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080046A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080046C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080046E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004700: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004720: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004740: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004760: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004780: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080047A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080047C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080047E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004800: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004820: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004840: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004860: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004880: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080048A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080048C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080048E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004900: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004920: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004940: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004960: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004980: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080049A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080049C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080049E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004A00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004A20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004A40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004A60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004A80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004AA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004AC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004AE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004B00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004B20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004B40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004B60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004B80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004BA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004BC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004BE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004C00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004C20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004C40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08004C60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008000: 00 00 FF FF AD DE 00 01 FF FF 00 01 AD DE 00 01 FF FF 00 01 AD DE 00 01 FF FF 00 01 0C 00 06 00
 0x08008020: 0C 00 08 00 0A 00 06 00 0A 00 08 00 0C 00 06 00 0C 00 08 00 0A 00 06 00 0A 00 08 00 AD DE 00 01
 0x08008040: FF FF 00 01 AD DE 00 01 FF FF 00 01 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00
 0x08008060: F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00
 0x08008080: F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 F0 BC 0C 00 AD DE 00 01 FF FF 00 01
 0x080080A0: AD DE 00 01 FF FF 00 01 08 00 06 00 08 00 08 00 AD DE 00 01 FF FF 00 01 48 00 0E 00 0A 00 06 00
 0x080080C0: 0A 00 08 00 08 00 06 00 08 00 08 00 5A 00 0E 00 0A 00 06 00 0A 00 08 00 0C 00 06 00 0C 00 08 00
 0x080080E0: 0A 00 06 00 0A 00 08 00 08 00 06 00 08 00 08 00 0A 00 06 00 0A 00 08 00 08 00 06 00 08 00 08 00
 0x08008100: AD DE 00 01 FF FF 00 01 48 00 0E 00 40 00 0E 00 78 00 0E 00 5A 00 0E 00 48 00 0E 00 5A 00 0E 00
 0x08008120: 48 00 0E 00 5A 00 0E 00 48 00 0E 00 5A 00 0E 00 48 00 0E 00 5A 00 0E 00 48 00 0E 00 5A 00 0E 00
 0x08008140: 78 00 0E 00 5A 00 0E 00 40 00 0E 00 48 00 0E 00 AD DE 00 01 FF FF 00 01 40 00 0E 00 48 00 0E 00
 0x08008160: 6E 00 0E 00 5A 00 0E 00 02 00 06 00 02 00 08 00 6E 00 0E 00 0A 00 06 00 0A 00 08 00 5A 00 0E 00
 0x08008180: 48 00 0E 00 40 00 0E 00 48 00 0E 00 5A 00 0E 00 48 00 0E 00 5A 00 0E 00 48 00 0E 00 08 00 06 00
 0x080081A0: 08 00 08 00 06 00 06 00 06 00 08 00 0E 00 06 00 0E 00 08 00 06 00 06 00 06 00 08 00 0A 00 06 00
 0x080081C0: 0A 00 08 00 0E 00 06 00 0E 00 08 00 08 00 06 00 08 00 08 00 0E 00 06 00 0E 00 08 00 06 00 06 00
 0x080081E0: 06 00 08 00 0E 00 06 00 0E 00 08 00 0A 00 06 00 0A 00 08 00 06 00 06 00 06 00 08 00 5A 00 0E 00
 0x08008200: 48 00 0E 00 5A 00 0E 00 48 00 0E 00 0A 00 06 00 0A 00 08 00 5A 00 0E 00 48 00 0E 00 5A 00 0E 00
 0x08008220: 48 00 0E 00 5A 00 0E 00 6E 00 0E 00 5A 00 0E 00 6E 00 0E 00 5A 00 0E 00 AD DE 00 01 FF FF 00 01
 0x08008240: 32 00 06 00 32 00 08 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008260: 01 00 10 00 64 00 06 00 64 00 08 00 5B 00 06 00 5B 00 08 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008280: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 40 00 0E 00 01 00 10 00
 0x080082A0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 5A 00 0E 00 01 00 10 00 6E 00 0E 00 01 00 10 00
 0x080082C0: 5A 00 0E 00 01 00 10 00 40 00 0E 00 01 00 10 00 5A 00 0E 00 01 00 10 00 41 00 06 00 41 00 08 00
 0x080082E0: 3E 00 06 00 3E 00 08 00 3D 00 06 00 3D 00 08 00 3C 00 06 00 3C 00 08 00 30 00 06 00 30 00 08 00
 0x08008300: 2F 00 06 00 2F 00 08 00 2E 00 06 00 2E 00 08 00 2D 00 06 00 2D 00 08 00 01 00 10 00 01 00 10 00
 0x08008320: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008340: 01 00 10 00 40 00 0E 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 02 00 06 00
 0x08008360: 02 00 08 00 03 00 06 00 03 00 08 00 06 00 06 00 06 00 08 00 02 00 06 00 02 00 08 00 03 00 06 00
 0x08008380: 03 00 08 00 AD DE 00 01 FF FF 00 01 01 00 10 00 64 00 06 00 64 00 08 00 31 00 06 00 31 00 08 00
 0x080083A0: 30 00 06 00 30 00 08 00 2F 00 06 00 2F 00 08 00 2E 00 06 00 2E 00 08 00 2D 00 06 00 2D 00 08 00
 0x080083C0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x080083E0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008400: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008420: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008440: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008460: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008480: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x080084A0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x080084C0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 5A 00 0E 00
 0x080084E0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 48 00 0E 00 01 00 10 00
 0x08008500: 5A 00 0E 00 01 00 10 00 01 00 10 00 01 00 10 00 40 00 0E 00 01 00 10 00 01 00 10 00 48 00 0E 00
 0x08008520: 01 00 10 00 40 00 0E 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008540: 01 00 10 00 01 00 10 00 5A 00 0E 00 01 00 10 00 01 00 10 00 40 00 0E 00 01 00 10 00 01 00 10 00
 0x08008560: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 48 00 0E 00
 0x08008580: 01 00 10 00 6E 00 0E 00 01 00 10 00 40 00 0E 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x080085A0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x080085C0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 5A 00 0E 00 01 00 10 00 01 00 10 00 40 00 0E 00
 0x080085E0: 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00 01 00 10 00
 0x08008600: 01 00 10 00 55 00 02 01 5A 00 0E 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008620: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008640: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008660: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008680: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080086A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080086C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080086E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008700: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008720: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008740: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008760: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008780: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080087A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080087C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080087E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008800: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008820: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008840: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008860: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008880: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080088A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080088C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080088E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008900: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008920: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008940: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008960: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008980: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080089A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080089C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x080089E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008A00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008A20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008A40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008A60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008A80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008AA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008AC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008AE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008B00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008B20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008B40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008B60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008B80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008BA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008BC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008BE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008C00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008C20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008C40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 0x08008C60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
####################DP LINK INFO START#########################
invalid parameter
chicago i2c read nok, maybe dp chip power off
####################DP LINK INFO END#########################
Debug mode set OK: hid !
LOOP[TRACE] 18. 8515: [DB_instance] init ok
LOOP[TRACE] 1a.38872: [EEPROM_read] EEPROM_read pos:258, size:2, val:ffff
LOOP[TRACE] 1a.31021: [pure_init] start ...
LOOP[TRACE] 1ce.38948: [pimax_board_id_get] board ADC value 0.805664
LOOP[TRACE] 1ce.31001: [pimax_board_id_get] P2 6.0
LOOP[TRACE] 1ce.25609: [LED_Init] entry
LOOP[TRACE] 1d3.31461: [led_set_state] led state is set to 0
LOOP[TRACE] 1d4.29468: [LED_Init] exit
LOOP[TRACE] 1d4.24679: [core_init] start ...
LOOP[TRACE] 1d5.12692: [chicago_reset] =(void), enter !
LOOP[TRACE] 1d8.39628: [chicago_set_current_state] >(state=0x00), curent_state=0x00, last_state=0x00
LOOP[TRACE] 240.38581: [panel_type_get] ADC VALUE: 710.595703; Panel type: panel_b5x
LOOP[TRACE] 240.29476: [__panel_b5x_instance] =(void), name=panel_b5x, type=0x03
LOOP[TRACE] 244.36198: [EEPROM_read] EEPROM_read pos:16, size:2, val:5a
LOOP[TRACE] 244.25862: [CHICAGO_init] out, current framrate: 90
LOOP[TRACE] 248.32626: [PANEL_DB_get_brainwarp_type] brainwarp_type is FALSE
LOOP[TRACE] 249.22746: [EEPROM_read] EEPROM_read pos:18, size:2, val:1
LOOP[TRACE] 249.12192: [dev_0_init] start ...
LOOP[TRACE] 249. 7153: [LTR303_Init] entry
LOOP[TRACE] 334.39646: [LTR303_Init] exit
LOOP[TRACE] 334.34878: [usb_init] entry
LOOP[TRACE] 406.12673: [usb_init] exit
LOOP[TRACE] 406. 8014: [dev_1_init] start ...
LOOP[TRACE] 408.39804: [EEPROM_read] EEPROM_read pos:260, size:2, val:55
LOOP[TRACE] 408.32504: [take_apart_init_check] entry:55
LOOP[TRACE] 408.26835: [take_apart_init_check] (=e_error_take_apart_spk) enter
LOOP[TRACE] 408.20523: [usb_init] entry
LOOP[TRACE] 408.15920: [usb_init] exit: not process
LOOP[TRACE] 409.36937: [led_set_state] led state is set to 9
LOOP[TRACE] 630.39507: [led_set_state] led state is set to 8
LOOP[TRACE] 857.39498: [led_set_state] led state is set to 9
LOOP[TRACE] a7e.39500: [led_set_state] led state is set to 8
LOOP[TRACE] ca5.39493: [led_set_state] led state is set to 9
LOOP[TRACE] ecc.39507: [led_set_state] led state is set to 8
LOOP[TRACE] 10f3.39502: [led_set_state] led state is set to 9
LOOP[TRACE] 131a.39501: [led_set_state] led state is set to 8
LOOP[TRACE] 1541.39460: [led_set_state] led state is set to 9
LOOP[TRACE] 1768.39454: [led_set_state] led state is set to 8
LOOP[TRACE] 198f.39467: [led_set_state] led state is set to 9
LOOP[TRACE] 1a13.34324: [EEPROM_read] EEPROM_read pos:8, size:2, val:2d
LOOP[TRACE] 1a14.21616: [EEPROM_read] EEPROM_read pos:10, size:2, val:2d
LOOP[TRACE] 3116.39460: [led_set_state] led state is set to 8
LOOP[TRACE] 3195.38413: [i2c_long_w] I2C1 NOK-8e:0,1-1,cause:3,cycle:3168
LOOP[TRACE] 3195.29748: [i2c_write] failed, retry to init i2c
LOOP[TRACE] 319a.23253: [i2c_long_w] I2C1 NOK-8e:0,1-1,cause:3,cycle:3164
LOOP[TRACE] 319a.14043: [i2c_write] failed, retry to init i2c
LOOP T341f: [led_set_state] led state is set to 9
LOOP T3649: [led_set_state] led state is set to 8
LOOP T3873: [led_set_state] led state is set to 9
LOOP T3a9d: [led_set_state] led state is set to 8
LOOP T3cc7: [led_set_state] led state is set to 9
LOOP T3ef1: [led_set_state] led state is set to 8
LOOP T411b: [led_set_state] led state is set to 9
LOOP T4345: [led_set_state] led state is set to 8
LOOP T456f: [led_set_state] led state is set to 9
LOOP T4799: [led_set_state] led state is set to 8
LOOP T49c3: [led_set_state] led state is set to 9
LOOP T4bed: [led_set_state] led state is set to 8
LOOP T4e17: [led_set_state] led state is set to 9
LOOP T5041: [led_set_state] led state is set to 8
LOOP T526b: [led_set_state] led state is set to 9
LOOP T5495: [led_set_state] led state is set to 8
LOOP T56bf: [led_set_state] led state is set to 9
LOOP T58e9: [led_set_state] led state is set to 8
LOOP T5b13: [led_set_state] led state is set to 9
LOOP T5d3d: [led_set_state] led state is set to 8
LOOP T5f67: [led_set_state] led state is set to 9
LOOP T6191: [led_set_state] led state is set to 8
LOOP T63bb: [led_set_state] led state is set to 9
LOOP T65e5: [led_set_state] led state is set to 8
LOOP T680f: [led_set_state] led state is set to 9
LOOP T6a39: [led_set_state] led state is set to 8
LOOP T6c63: [led_set_state] led state is set to 9
LOOP T6e8d: [led_set_state] led state is set to 8
LOOP T70b7: [led_set_state] led state is set to 9
LOOP T72e1: [led_set_state] led state is set to 8
LOOP T750b: [led_set_state] led state is set to 9
LOOP T7735: [led_set_state] led state is set to 8
LOOP T795f: [led_set_state] led state is set to 9
LOOP T7b89: [led_set_state] led state is set to 8
LOOP T7db3: [led_set_state] led state is set to 9
LOOP T7fdd: [led_set_state] led state is set to 8
LOOP T8207: [led_set_state] led state is set to 9
LOOP T8431: [led_set_state] led state is set to 8
LOOP T865b: [led_set_state] led state is set to 9
LOOP T8885: [led_set_state] led state is set to 8
LOOP T8aaf: [led_set_state] led state is set to 9
LOOP T8cd9: [led_set_state] led state is set to 8
LOOP T8f03: [led_set_state] led state is set to 9
LOOP T912d: [led_set_state] led state is set to 8
LOOP T9357: [led_set_state] led state is set to 9
LOOP T9581: [led_set_state] led state is set to 8
LOOP T97ab: [led_set_state] led state is set to 9
LOOP T99d5: [led_set_state] led state is set to 8
LOOP T9bff: [led_set_state] led state is set to 9
LOOP T9e29: [led_set_state] led state is set to 8
LOOP Ta053: [led_set_state] led state is set to 9
LOOP Ta27d: [led_set_state] led state is set to 8
LOOP Ta4a7: [led_set_state] led state is set to 9
LOOP Ta6d1: [led_set_state] led state is set to 8
LOOP Ta8fb: [led_set_state] led state is set to 9
LOOP Tab25: [led_set_state] led state is set to 8
LOOP Tad4f: [led_set_state] led state is set to 9
LOOP Taf79: [led_set_state] led state is set to 8
LOOP Tb1a3: [led_set_state] led state is set to 9
LOOP Tb3cd: [led_set_state] led state is set to 8
LOOP Tb5f7: [led_set_state] led state is set to 9
LOOP Tb821: [led_set_state] led state is set to 8
LOOP Tba4b: [led_set_state] led state is set to 9
LOOP Tbc75: [led_set_state] led state is set to 8
LOOP Tbe9f: [led_set_state] led state is set to 9
LOOP Tc0c9: [led_set_state] led state is set to 8
LOOP Tc2f3: [led_set_state] led state is set to 9
LOOP Tc51d: [led_set_state] led state is set to 8
LOOP Tc747: [led_set_state] led state is set to 9
LOOP Tc971: [led_set_state] led state is set to 8
LOOP Tcb9b: [led_set_state] led state is set to 9
LOOP Tcdc5: [led_set_state] led state is set to 8
LOOP Tcfef: [led_set_state] led state is set to 9
LOOP Td219: [led_set_state] led state is set to 8
LOOP Td443: [led_set_state] led state is set to 9
LOOP Td66d: [led_set_state] led state is set to 8
LOOP Td897: [led_set_state] led state is set to 9
LOOP Tdac1: [led_set_state] led state is set to 8
LOOP Tdceb: [led_set_state] led state is set to 9
LOOP Tdf15: [led_set_state] led state is set to 8
LOOP Te13f: [led_set_state] led state is set to 9
LOOP Te369: [led_set_state] led state is set to 8
LOOP Te593: [led_set_state] led state is set to 9
LOOP Te7bd: [led_set_state] led state is set to 8
LOOP Te9e7: [led_set_state] led state is set to 9
LOOP Tec11: [led_set_state] led state is set to 8
LOOP Tee3b: [led_set_state] led state is set to 9
LOOP Tf065: [led_set_state] led state is set to 8
LOOP Tf28f: [led_set_state] led state is set to 9
LOOP Tf4b9: [led_set_state] led state is set to 8
LOOP Tf6e3: [led_set_state] led state is set to 9
LOOP Tf90d: [led_set_state] led state is set to 8
LOOP Tfb37: [led_set_state] led state is set to 9
LOOP Tfd61: [led_set_state] led state is set to 8
LOOP Tff8b: [led_set_state] led state is set to 9
LOOP T101b5: [led_set_state] led state is set to 8
LOOP T103df: [led_set_state] led state is set to 9
LOOP T10609: [led_set_state] led state is set to 8
LOOP T10833: [led_set_state] led state is set to 9
**Author:** ![hammerhead\_gal](https://forum.openmr.com/user_avatar/forum.openmr.com/hammerhead_gal/32/24859_2.png) [@hammerhead\_gal](https://forum.openmr.com/u/hammerhead_gal)\
**Post date:** [July 27, 2022, 6:34am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039/2 "2022-07-27T06:34:38Z")
</div>
Hi Isabel：
Welcome to OpenMR ! 😀 🙌
You may need to submit a ticket to our helpdesk;[Submit a ticket : Pimax Support](https://support.pimax.com/en/support/tickets/new)
Our technician will be help you to diagnose the tracking problem and fix it.
If please let me know if you didn’t receive any response from our support!
Sincerely
**Post date:** [July 27, 2022, 6:56am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039/3 "2022-07-27T06:56:30Z")
</div>
Hello good morning, I bought this viewer from another person, I think I have no guarantee, can the technical service assist me?
The truth is that I am very worried, because I am not able to solve the problem by myself
How should I make the ticket in my position?
Thank you for your attention
**Post date:** [July 27, 2022, 7:25am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039/4 "2022-07-27T07:25:36Z")
</div>
Hello, I have created a Ticket:
Pimax 5k Plus (Yellow Light after Update 269) #30085
Assigned to : Criss Wang
I am not sure that all the data is correct, but I hope you can help me and solve my problem.
**Post date:** [July 27, 2022, 7:45am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039/5 "2022-07-27T07:45:49Z")
</div>
that’s will do .
I 'll take a look at it with the technician and Criss will reply you later
**Post date:** [July 27, 2022, 7:49am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039/6 "2022-07-27T07:49:00Z")
</div>
Thank you very much
**Post date:** [July 28, 2022, 5:01am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039/7 "2022-07-28T05:01:00Z")
</div>
My problem was solved by the Pimax technical service.
Thank you hammerhead\_gal and Criss Wang for the attention you gave me.
Thank you very much for serving me in my situation, really, thank you very much.
Now I can continue to enjoy my Pimax 5k Plus.
**Post date:** [September 26, 2022, 5:01am UTC](https://forum.openmr.com/t/help-pimax-5k-plus-yellow-light-after-update/39039/8 "2022-09-26T05:01:26Z")
</div>
