Hello,
with a little adjustment do You think it’s a good option to the squishy standard-issue headstrap?
Cost is about 30.00 US$ shipped.
Any comment will be apreciated.
Thanks in advance.
p.s.: I do not know if links are permitted or not but You can find it on Alibaba.
I actually had the same thought but then I saw that the headphones are not part of the strap and locks into the hmd plus many have commented on the same product in AliExpress that the straps are poorly made and the locking mechanism loosens when the user moves about. So no…
Still, it may be good for watching movies and that.
Might work okay… But only connecting to top strap likely too wobbly.
You might want to consider my poor man’s cost should be under $25.
https://community.openmr.ai/t/poor-mans-deluxe-headstrap/9708?u=heliosurge
