Hand module and DCS
Yes. You instruct VoiceAttack to launch a command as administrator, that starts/stops the service. Not having VoiceAttack stop a process.
C:\windows\system32\sc stop LeapService
Like with a batch file, or a command line, or with the ‘run’ dialog. Just like running ‘explorer.exe’ or ‘cmd.exe’, ‘C:\windows\system32\sc’ is an executable program, which manages these services. You can also run ‘services.msc’ to get a GUI for managing these services - though I think TaskManager includes this functionality now as well.
VoiceAttack required me to add ‘C:\windows\system32’ , as in ‘C:\windows\system32\sc’ (without the single quotes) .
no motion - yet 3 dof reality being very heavily contemplated
too much tied into it to think about it.
heres my set up
S
Very very nice! I like the simplistic, clean design! Yeah, we won’t discuss money anymore, that picture says it all! :grin: Very nice!
As to the motion. A lesson that would have saved me a lot of money: there seem to be a couple of different methods of achieving “motion”. The cheapest seems to be oriented on a U-joint. Yep, the same one in older vehicles. I have a couple on my '76 ford drive shaft.
The problem with this approach is that U-joints have a small amount of play or slack or whatever you want to call it. While this isn’t a problem for most uses, when you place one at the bottom pivot point of your chair, that small amount of slack amounts to a good 6 inches (about 9.5cm) of play at your head. That is actually a significant amount of movement that is not matched by your visual input.
I find that flying helicopters isn’t too bad, but driving is an issue if you are at all sensitive to VR sickness.
When I say that flying helicopters isn’t too bad, it means that I can cope, that doesn’t mean that the slop isn’t really obvious.
My advice would be not to waste your time or money on a U-joint based motion platform.
Fascinating. I’ve got it working but I suspect that I’m still doing it differently than you are: for me, the “.exe” on the end is needed.
So, for me, the procedure is:
under New Command, I click Other/Windows/Run an Application. In this window, in the first field, I enter ‘C:\windows\system32\sc.exe’ . Next line, With these Parameters: ‘stop LeapService’. And ‘C:\windows\system32’ for the next line; Working Directory.
To start it, I make another command that has ‘start LeapService’ instead.
I do have to set VA to launch as admin. This is the only time that I’ve had to do this, so I’m wondering if the way that you are doing it might make it possible to start and stop the service without that step.
While I agree that the new driver is a bit better, imho, it still sucks. Next to check out the other driver.
Just out of curiosity, I was noticing that the hand emulation for the original SDraw driver only had the thumb and two fingers and I was wondering if you think that this might have anything to do with the lousy functionality? I’m thinking that tracking 5 fingers should lead to more accuracy than tracking 3 fingers.
Edit: note to anyone trying this. Make sure that you have the service started again before you exit SteamVR or PE won’t accept your hands again until PE is restarted.
thanks for the moving platform advise :grinning:
S
Check this one out, almost looks like your rig! Or that it was made for your rig…
By VRXsim
I may have ‘%system32’ added to my system PATH variable. I will modify my VoiceAttack macros so this does not become a problem in the future. Thank you for testing and reporting this!
Not having VoiceAttack use administrator permissions is a bad idea generally. However, I do sometimes use ‘nircmd’ with a batch script to elevate permissions more selectively or forcibly.
Flight sim is the only application I expect that driver to be useful for. Wand/Index controllers are an approximation of what human hands can do, that could not work efficiently with empty hands in empty space to begin with. Such controllers do not map completely, intuitively, or at all angles, to human hands.
Configuration file format for that driver does not seem to be stable, some of the defaults are not sane, any real controllers cause conflicts, and the accuracy is perhaps 100x behind what Leap Motion is capable of.
Native Leap Motion support - in OVRDrop and such - is what we need.
WOW thats even out of my price range!!
S
Agreed!
For me, that other driver just causes SteamVR to go nuts. With the updated SDraw driver I can’t get it to recognize any gestures except the trigger. Going backwards here, lol.
Oh, well, it was fun to play with it. And with ability to turn it on and off, I’ll probably keep poking at it(pun intended), but I probably would have been more impressed if SweViver and Armin hadn’t already spoiled me. Really makes one appreciate their work!
Nice, tho, isn’t it?
Some time ago I thought I saw a pneumatic variation (the one in that link was ‘pneumatic’) for less than $10,000us, but I didn’t see it this time in my quick search. When you’re ready to look, now you know what you’re looking for! And what it’ll cost you!
I need to find me a rich uncle! Or Aunt…
I think that and grip are all it is capable of. And maybe not grip, I can’t be sure.
Which makes sense. Mapping gestures to invisible objects is not going to be a very intuitive approach.
Nonetheless, I am highly confident the hand tracking can be far more accurate than what we are seeing in Pimax Experience currently.
Indeed, Pimax Experience itself is reason enough to justify the hand tracker investment. Finally, put the VR headset on, and VR just works.
No more hoping SteamVR works well enough today just to get to Virtual Desktop first.
