GPU Upscaling per game not working
Title: GPU Upscaling per game is not working
Describe Bug Below:
When trying to configure per-game settings and selecting GPU Upscaling in a specific game (with it being off globally), it is being set globally.
While looking more into it, I found the JSON config files and noticed that the per-game files don’t even have the GPU Upscaling field, so it means that the program works with only one global variable.
Steps to Reproduce
  1. Go to Device settings → Games → Common Setting
  2. Set GPU Upscaling to None
  3. Select a specific game
  4. Set GPU Upscaling to NIS
  5. Apply and save the game config
  6. Go back to Common Setting
  7. GPU Upscaling is set to NIS globally
Pimax Hmd Model: Pimax Crystal Light
Firmware version: 1.43.9
System Info
OS: Windows 11
Build Version: 25H2 26200.8246
CPU Model: 13th Gen Intel(R) Core™ i5-13400 (2.50 GHz)
Memory: 32GB
GPU Model/Brand: RTX 5080
GPU Driver Version: 596.49
Yes, the GPU Upscaling and Sharpening settings tend to be applied globally.
Will that be changed/fixed at some point? The main reason I need different profiles is to enable upscaling for some games, but not globally
For the time being, no.
However, I’ve already asked the devs to revise the logic so users can adjust all settings based on individual profiles.
