I ordered the GPU with the 5k+ but was wondering what exactly were the specs (ports, etc.) of the GPU I’d be getting?
Edit. I looked on Amazon and I could get both the Pimax 5k+ AND the 2080 GPU I know that has all the ports I need TOMORROW for the same price I’ve paid Pimax directly and have been waiting for. What’s up with that?
Amazon has a fantastic, industry-defining fulfilment service. Pimax is a startup company with a webstore. There’s no way they could ever hope to compete, which is presumably why they’ve chosen to leverage Amazon where viable.
you ordered and paid something without knowing what it is ?
what says your order ? just GPU ? or it list a particular model ?
It’ a chinese hardware manufacturer called COLORFUL (they’re big in China apparently - biggest GPU manufacturer according to this).
I’m pretty sure this is the card:
https://en.colorful.cn/contents/388/790.html
Here’s the specs:
| Graphics_Card_Model |
iGame GeForce RTX 2080 Advanced |
| GPU |
GeForce RTX 2080 |
| GPU_Code_Name |
TU104 |
| Manufacturing_Process |
| CUDA_CORES |
2944 |
| Core_Clock |
Base:1515Mhz;Boost:1710Mhz |
| ONE-KEY_OC |
| Memory_Clock |
14Gbps |
| Memory_Size |
8 GB |
| Memory_Bus_Width |
256bit |
| Memory_Type |
GDDR6 |
| DirectX_Shader_Model |
DirectX 12.1 |
| OpenGL |
OpenGL 4.5 |
| Max_Resolution |
| Display_Ports |
3*DP+HDMI+USB-C |
| Multi_GPU |
| Power_Connector |
8pin + 6pin |
| Cooling_System_Type |
Air Cooling |
