Do you think other games have this kind of launch options? It would be so cool if you could just change it like that!
@VR-TECH Nope, it’s still a loaner, but StarVR didn’t get back to me for a while, so I still have the device.
I take that you are also adding the Mura command?
When I added the mura command, I don’t really notice a difference except maybe less clarity from a far distance. Maybe it’s just because I’m not sensitive to it like you and vrftw. So I’d like to know when you try it.
Many (most?) games have launch options, but it varies by game. Some only have minimal options, while others have extensive options.
I’m really wondering how different our units are… Maybe it’s because I also have a Pimax. I see mura on my 8k+ but 99% less.
Awesome. It is possible there is some standard command line that is recognized by all games written with a certain engine, i.e. unreal or unity. If we could figure out the no_cull command line parameter for either of those engines, if there is one built in, that would be awesome indeed. For example, in terminator salvation you can use the parameter -vr to launch it in VR, but its kind of messed up when it comes time to shoot.
Yes, I think it’s possible that other engines/games might have a similar command line. Half Life Alyx runs on the Source 2 engine built by Valve. I’m going to look into getting rid of culling in other games like Boneworks now. Either by finding a way to disable it or by creating a Unity project with StarVR’s frustum script, compiling the project and then doing a difference comparison between the same project with and without the script and then seeing if I can implement universally compiled files into Boneworks that way. Ideally I’ll try the easiest route first by finding command params, etc.
what’s really sad about this is that, we all saw the Pimax at Valve HQ when Norm from tested was claiming to have issues with what he was seeing with Pimax
Did Valve even actually use the Pimax to test at all! To think all they had to do is tweak so settings for Pimax headsets for it to work correctly.
It makes me think they didn’t test at all. Did you post this on Hl Altx forum maybe you can get them to fix this in the game so we don’t have to do it ourselves.
starVR has mura ? is this it’s one flaw?
Maybe try cheat engine, it may show you diffetences in memory, if the difference isn’t obvious in files then there is probably a real time patch we can do in memory
although we would risk getting VAC banned so …
Also maybe sticky the solution at the top of this thread so new users dont have to scroll through a million posts to find the solution.
I saw you posted on reddit
Yep it’s the main problem to me. The resolution is fine. It’s really visible on some colors. It might get patched hopefully.
Flaw 1: Price is too high. ($3200) for 90hz bare-bones headset.
Flaw 2: Resolution is too low (1830 x 1464 per eye).
If it was 1/2 price and 4K per eye, it would be a genuine step up from the non OLED, non 90hz Pimax 8K-X.
apparently the resolution being lower is misleading
due to the magic of the lenses it actually has less sde than a 8kx.
@mixedrealityTV words not mine.
It definitely has more SDE than 8kx.
so the the low resolution will actually make it easier to see details and read text or how is it misleading again?
