Downloads Collection of PiPlay/PiTool Software and similar
Awesome didn’t realize we were in your topic. Doh! :laughing:
#Push𐂃𐂃𐂃𐂃𐂃𐂃𐂃𐂃𐂃𐂃𐂃𐂃𐂃𐂃𐂃
Hi Playa and others what is the last Firmware for the og 8k?
Also today my 5k+ auto updated to FW 271 and the left screen now stays off :man_facepalming:
@PimaxQuorra and @anon57422158 is there a debug FW for the 5k+ model 203 serial?
Hey Dan,
I’m checking the firmware version with software team.
But I didn’t hear any debug FW for 5K+, maybe they have alternative FW to address your left screen’s issue.
Hi,
The latest debug build i should have is the β€œP2_DEBUG_8KX_N7_0_M299_t20211203180915_rc879f9b_90only”
Since the naming never makes sense, i assume its version M299 build 20211203.
The nearest stable build is 20211011.
If you need to downgrade your 5k+, the nearest version i have is M269.
The 299 FW is for the 8kX. 271 waa the 5k+; I have tried the 269 but if it is a FW issue may need a specific version.
With the 8kX had to install 296 to clear the issues created from 299.
Hi Dan,
Could you please download and flash the 5K Plus with this firmware?
Thanks will give it a try.
There is a problem with the link it is not letting me download the file.
Okay for some reason had to open link on pc. Strange.
Okay tried that Firmware on the 5k+. Left screen still Stays off. Lighthouse Tracking is broken and this Firmware causes main screen to flicker off. Usually with sometime main monitor will turn back on. Seems to be causing maybe an increased power draw?
Will see about rolling back Firmware as Lighthouse tracking was working. After I see about getting og 8k Re Flashed and working will attempt a cable swap.
Need a break. :confused: 8kX still working fine. :smiling_face_with_three_hearts:
Just need to get other 2 up and running.
https://keybase.pub/playa/Pimax/PiTool/
#Push𐂃𐂃𐂃𐂃𐂃
#Push𐂃𐂃𐂃𐂃𐂃
#Push𐂃𐂃𐂃𐂃𐂃
