# DMAS setup on crystal light
**URL:** <https://forum.openmr.com/t/dmas-setup-on-crystal-light/41885>\
**Category:** Pimax Crystal\
**Created:** [March 15, 2025, 1:13am UTC](https://forum.openmr.com/t/dmas-setup-on-crystal-light/41885 "2025-03-15T01:13:39Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Smeghead](https://forum.openmr.com/letter_avatar_proxy/v4/letter/s/f1d935/32.png) [@Smeghead](https://forum.openmr.com/u/Smeghead)\
**Post date:** [March 15, 2025, 1:13am UTC](https://forum.openmr.com/t/dmas-setup-on-crystal-light/41885/1 "2025-03-15T01:13:39Z")
</div>
Hi, I’ve installed the DMAS upgrade on my crystal light but am a bit confused about the sound settings etc.
I’m on a GTX 4080 and have installed the geforce audio drivers.
The speakers work fine but am unsure if they are working correctly, some of the info I have found online suggest you need to set the speaker configuration to 7.1 but mine only show up as stereo and cannot be altered.
Is this correct or is something amiss ?
**Author:** ![SmallBaguette](https://forum.openmr.com/user_avatar/forum.openmr.com/smallbaguette/32/24247_2.png) [@SmallBaguette](https://forum.openmr.com/u/SmallBaguette)\
**Post date:** [March 15, 2025, 1:15pm UTC](https://forum.openmr.com/t/dmas-setup-on-crystal-light/41885/2 "2025-03-15T13:15:58Z")
</div>
If the speakers work fine then I don’t tihnk you need to worry. I had to set the 7.1 option up before but the audio was a garbled mess until I done that, so if your audio sounds fine then it should be good to go.
**Post date:** [March 15, 2025, 9:09pm UTC](https://forum.openmr.com/t/dmas-setup-on-crystal-light/41885/3 "2025-03-15T21:09:06Z")
</div>
ok, thanks for the reply
