I’ve seen some people that are able to play DiRT Rally with the pimax but the threads are some months old.
It seems simple. Patch the game with Revive and run it on steam. But it does not work for me. I launch the game, it says “Dirt Rally does not support VR,…”, I press OK and it launches normally on my monitor. The HMD stays at the SteamVR Home.
My specs:
PC: GTX 1070, i5 6600k, 500GB SDD, 8GB RAM
Latest PiPlay (1.2.91) on Pimax Mode
Latest Revive (1.1.12)
Latest Nvidia drivers
Normal SteamVR (tried the beta but it also did not work) running in Direct Mode
DiRT Rally version 1.22
What I did:
Launched Piplay (admin), connected the HMD on Pimax mode, opened Steam and launched Steam VR, right clicked on the revive icon and patched “drt.exe”, un-checked the “Use Desktop Game Theatre While Steam VR is running” and launched the game via steam. It does not work.
Revive patches 3 .dlls: Openvr_api, Xinput1_3 and Xinput 9_1_0
Do I need any specific versions to make it run?
Any help would be apreciated.
Aside from Revive I don’t have anything else from Oculus installed as I dont own a Rift.
Should I install the Rift setup? If it’s required I find it strange, no guide I saw mentioned it.
Unfortunately have been a bit lazy with work & other priorities.
But have 5 days off so should be able to invest sometime into tinkering.
Strange thing Dirt at least was launching just nit in hmd til 2nd or 3rd patch attempt. But i di know that part of the Amd driver install was blocked. My old win10 dual 7950 cf i could run 3dmark vulkan api test. In the win10 pro r9 390 the Vulkan Api test is greyed out due to vulkan not installed.
Will also get a chance to install latested piplay think i still only have 1.2.91.
