# Crystal bug with firmware 1.4.0
**URL:** <https://forum.openmr.com/t/crystal-bug-with-firmware-1-4-0/41072>\
**Category:** Report Bugs\
**Created:** [August 20, 2023, 2:39pm UTC](https://forum.openmr.com/t/crystal-bug-with-firmware-1-4-0/41072 "2023-08-20T14:39:23Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Marc\_63](https://forum.openmr.com/letter_avatar_proxy/v4/letter/m/a87d85/32.png) [@Marc\_63](https://forum.openmr.com/u/Marc_63)\
**Post date:** [August 20, 2023, 2:39pm UTC](https://forum.openmr.com/t/crystal-bug-with-firmware-1-4-0/41072/1 "2023-08-20T14:39:23Z")
</div>
My Crystal no longer turns off since I updated the firmware to version 1.4.0.
After pressing the On/Off button, the Crystal switches off, but automatically opens again after 1 or 2 seconds. Now the only way to switch off the Crystal is to disconnect the two USB cables on the Power Hub. I know another owner with the same problem.
**Post date:** [August 22, 2023, 9:38am UTC](https://forum.openmr.com/t/crystal-bug-with-firmware-1-4-0/41072/2 "2023-08-22T09:38:28Z")
</div>
Hi,
Perhaps you should consider updating the client to v1.14.04 and the headset firmware to version 0807. If you want to power off the headset, press and hold the power button for 4-5 seconds.
**Post date:** [August 22, 2023, 11:38am UTC](https://forum.openmr.com/t/crystal-bug-with-firmware-1-4-0/41072/3 "2023-08-22T11:38:15Z")
</div>
I’ll check it out.
Thank you for your reply.
**Post date:** [August 22, 2023, 1:09pm UTC](https://forum.openmr.com/t/crystal-bug-with-firmware-1-4-0/41072/4 "2023-08-22T13:09:06Z")
</div>
After checking, my Client is in version 1.14.03 and there is no possibility of upgrading to version 1.14.04.
This morning my helmet stayed closed 6 times out of 8.
Waiting for a new firmware update to solve this problem definitively.
