Will have to wait for the review, but I can say it seems similar to the headband of the Lenovo Explorer and personally I found the comfort to far outweigh any issue of sweat. Plus, the fabric was removable and machine washable, so I hope Pimax will do the same.
My CK question is:
Has it been fully tested to accommodate different size glasses? The aperture is narrower than before. While I reckon my thin frames should be OK, I’m sure others would appreciate confirmation of this
They should make or vr cover should make PU leather option so it doesn’t absorb sweat and can be easily wiped down between users if switching off at a party etc.
