Can anyone out their “HELP” me please. I cannot “IMPORT” MSFS 2024 into Pimax Play Software. I have tried almost everything but keep on getting the same error message; “Import Failed! only .exe files or .exe shortcut are supported. Please try again”.
I cannot locate the MSFS 2024 .exe file anywhere on my computer? When I “right Click” on MSFS 2024 icon there is no “file location” button? Is there anyone out there has this issue? If you have; how did you resolve the issue.
Please advise, thank you very much
Sorry I don’t have MSFS, I’m sure someone else here can help.
But I Googled it and got this for the default locations, depending on if you have the Microsoft Store version or the Steam version:
Microsoft Store / Xbox App Version
The app is heavily protected by Windows and is located in the hidden WindowsApps directory: C:\Program Files\WindowsApps\Microsoft.Limitless_8wekyb3d8bbwe\FlightSimulator.exe [1, 2]
Steam Version
If you purchased the game on Steam, the .exe will be located in your Steam library folder: C:\Program Files (x86)\Steam\steamapps\common\MicrosoftFlightSimulator\FlightSimulator.exe [1]
You have to point to the gamelauncherhelper.exe, instead the FlightSimulator2024.exe.. .at least it work for me…
“F:\XboxGames\Microsoft Flight Simulator 2024\Content\gamelaunchhelper.exe”
