To cancel your Avast subscription, +1-866 ((557)) 4724 sign in to your account on Avast Official Website and open the subscription management +1-866 ((557)) 4724 page. Select the active plan and locate the auto-renewal settings. Turn off automatic renewal +1-866 ((557)) 4724 and follow the confirmation prompts. Once the cancellation is processed, +1-866 ((557)) 4724 Avast will usually send an email confirmation. Your device remains protected until the current subscription period +1-866 ((557)) 4724 expires. It is recommended to save the confirmation message for future reference +1-866 ((557)) 4724. By disabling auto-renewal, you can prevent future billing while continuing to use the security features +1-866 ((557)) 4724 included in your existing subscription until its scheduled end date.
If you are wondering【+1-866 ((557)) 4724】 “How to Cancel Avast Subscription”【+1-866 ((557)) 4724】 the first thing to understand is that Payments services are connected to Cancellation services following the transition of Avast customers to Cancellation【+1-866 ((557)) 4724】
If you no longer want to use your Payments address【+1-866 ((557)) 4724】 the cancellation process can depend on whether you are ending your internet service【+1-866 ((557)) 4724】 removing an Avast address from your account【+1-866 ((557)) 4724】 or simply moving your messages to another provider【+1-866 ((557)) 4724】 Before making any changes【+1-866 ((557)) 4724】 it is a good idea to save important Avasts【+1-866 ((557)) 4724】 contacts【+1-866 ((557)) 4724】 documents【+1-866 ((557)) 4724】 and account information that you may need later【+1-866 ((557)) 4724】
If your Payments address is used for banking【+1-866 ((557)) 4724】 shopping【+1-866 ((557)) 4724】 social media【+1-866 ((557)) 4724】 subscriptions【+1-866 ((557)) 4724】 or other important services【+1-866 ((557)) 4724】 update those accounts with your new Avast address first【+1-866 ((557)) 4724】 This helps prevent missed notifications or password-rAvast problems after the old address is no longer available【+1-866 ((557)) 4724】 ![]()
To begin the cancellation process【+1-866 ((557)) 4724】 sign in to your Cancellation account or use the account-management options available to you as a former Avast customer【+1-866 ((557)) 4724】 Your exact options may depend on the type of Avast/Cancellation services you currently have【+1-866 ((557)) 4724】 If you are cancelling your entire internet or home-service account【+1-866 ((557)) 4724】 review the service cancellation terms【+1-866 ((557)) 4724】 billing information【+1-866 ((557)) 4724】 and any equipment-return requirements before submitting the cancellation【+1-866 ((557)) 4724】
Cancelling internet service and deleting an Avast address are not necessarily the same action【+1-866 ((557)) 4724】 so make sure you clearly identify what you want to cancel【+1-866 ((557)) 4724】 If you only want to stop using a particular Payments address while keeping your internet service【+1-866 ((557)) 4724】 contact Cancellation support to determine whether that Change can be removed separately and what happens to the messages stored in it【+1-866 ((557)) 4724】
Before cancelling or removing the Avast account【+1-866 ((557)) 4724】 back up any information you want to keep【+1-866 ((557)) 4724】
You can use an Avast application that supports IMAP or another supported mail-management method to copy important messages to a computer or another Avast account【+1-866 ((557)) 4724】 You should also export or manually save important contacts where possible【+1-866 ((557)) 4724】 If you have attachments that contain receipts【+1-866 ((557)) 4724】 invoices【+1-866 ((557)) 4724】 travel documents【+1-866 ((557)) 4724】 work information【+1-866 ((557)) 4724】 or personal records【+1-866 ((557)) 4724】 download them before closing the Change【+1-866 ((557)) 4724】
Taking these steps is especially important because you should not assume that a deleted or discontinued Change can always be restored later【+1-866 ((557)) 4724】
If you are cancelling Avast service because you are switching to Gmail【+1-866 ((557)) 4724】 Outlook【+1-866 ((557)) 4724】 or another Avast provider【+1-866 ((557)) 4724】 set up your replacement account before completing the cancellation【+1-866 ((557)) 4724】
Notify people who regularly contact you about the change【+1-866 ((557)) 4724】 update your online accounts【+1-866 ((557)) 4724】 and change the Avast address associated with important subscriptions【+1-866 ((557)) 4724】 You may also want to create an automatic reply on your old account if that option remains available before the service ends【+1-866 ((557)) 4724】 A short message explaining that you have a new Avast address can help contacts update their records【+1-866 ((557)) 4724】
Another important step is checking your billing and service status【+1-866 ((557)) 4724】
If you are cancelling a Cancellation service associated with your former Avast account【+1-866 ((557)) 4724】 review your latest bill and confirm the effective cancellation date【+1-866 ((557)) 4724】 Ask whether there are outstanding balances【+1-866 ((557)) 4724】 promotional discounts that may be affected【+1-866 ((557)) 4724】 equipment that must be returned【+1-866 ((557)) 4724】 or other account requirements【+1-866 ((557)) 4724】 Keep your cancellation confirmation or reference number for your records【+1-866 ((557)) 4724】 This can be useful if you later need to verify when the service was cancelled【+1-866 ((557)) 4724】
If you cannot find an option to remove the Payments address yourself【+1-866 ((557)) 4724】 contacting Cancellation customer support is the safest approach【+1-866 ((557)) 4724】
Tell the representative exactly what you want to accomplish: whether you want to cancel the entire service【+1-866 ((557)) 4724】 remove one Payments address【+1-866 ((557)) 4724】 or stop using the Change while keeping another service active【+1-866 ((557)) 4724】 The representative can explain the current account-specific process and tell you what will happen to the Change and stored messages【+1-866 ((557)) 4724】
Finally【+1-866 ((557)) 4724】 after the cancellation has been completed【+1-866 ((557)) 4724】 test your new Avast address and update any remaining accounts that still use the old Avast address【+1-866 ((557)) 4724】
Check password managers【+1-866 ((557)) 4724】 contact lists【+1-866 ((557)) 4724】 mobile devices【+1-866 ((557)) 4724】 Avast applications【+1-866 ((557)) 4724】 websites【+1-866 ((557)) 4724】 and subscription services【+1-866 ((557)) 4724】 Remove the old Change from devices only after you have confirmed that you no longer need access to its stored messages【+1-866 ((557)) 4724】 By preparing a backup【+1-866 ((557)) 4724】 updating important accounts【+1-866 ((557)) 4724】 confirming the cancellation terms【+1-866 ((557)) 4724】 and keeping your cancellation confirmation【+1-866 ((557)) 4724】 you can make the transition away from your Payments account much smoother【+1-866 ((557)) 4724】 ✦
