Can We Get Acknowledgement of the Pimax Specific RTX 4090 Latency / Lag Issue please?
Never tried 528.02 until now as reports here suggested no change. Unfortunately I’m in that category as well, it’s actually even worse as this driver introduced ghosting as well :frowning_face:
I tried it and lag is still bad. 522.25 still the smallest lag.
I’ve got a Gainward 4090 since yesterday and first installed and tested it with the former 527.56 => slight lags, although a little less annoying than with the 4080 imho.
Later that day, I upgraded to 528.02. => no change, still slight lags, no improvement compared to 527.56.
Given all these issues with the new HMD’s from Nvidia and AMD, I think I will keep my 3090 through the beta testing of the crystal and likely until after the 12K’s release. By then both companies should have this sorted. In the meantime, SweViver said the Crystal would bo ‘ok’ on a 3070, so it should be fine on the 3090.
I almost pulled trigger and brought 4090 but now im holding off until this all gets sorted out as well. 3080 still good enough.
There’s a post on the VR subreddit claiming disabling direct display helps with tracking lag, if anyone wants to try this.
I already experimented with this to try and fix my stutters a while ago, no luck.
I’m still installing and uninstalling MSI centre every day but is working flawlessly at least :confused:
Had same lag issue with 8KX and Asus TUF 4090 OC in iRacing. I returned the card because it was unusable with this issue. I’m now considering to get MSI card, but I’m quite sceptical it will be any different than Asus.
Pimax, please give info have you found what is causing this and when we get fix for this !!
I have pre orderd Crystal, but I think I won’t buy it, until it’s sure that it don’t have same lag issue.
Its really disappointing that this issue hasnt.been addressed by nvidia. It seems its a problem with other vr headsets as well.
That worked surprisingly well. I finally played bonelab without stutter by the MSI install/uninstall method. Kudos to you!
Nvidia has issued a beta driver to me for the issue.
There are 2 issues. The lag based unplayable issue seems to be mostly faced by MSI users and does not affect me as I use an Asus Rog setup.
The other issue is the regular jitter when using any monitoring software which seems to affect most 4090 users.
Just tried the beta for a couple of hours and it’s looking good. Will try for a few more hours before giving a positive feedback to Nvidia.
So there is hope in the near future for all 4090 and Pimax users.
Wheels are in motion, thats good news!
Possible temp fix - Hey everyone, thought I’d throw my hat in the ring for the weird lag/ tracking drag issue.
I’m in a completely different situation than most of you, yet share the same problem - I have a 4070ti, and a Vive Pro 1, (90hz) and since upgrading from a 5600xt to the 4070ti I have the headtracking motion lag issue. about 300-400ms I’d guess. I have come across others who have this EXACT problem with the 4070ti, 4080, and 4090 - across VP1, VP2, Pimax and Varjo headsets. So at least we share that in common.
All my stats are in the green. Funny thing is if you watch the controller in the headset, the controller does NOT have the lag, which means its purely something to do with the relay of the head tracking. I do NOT have this problem with my quest 2 either, while using steamvr as well.
However, I found a bit of a temp fix. I’m the guy on the reddit thread that disabled direct display and got it to go away. As long as I’m running the VP1 as a extra monitor, and just turn it on when I want to use steamvr, with DD off the headtracking lag is COMPLETELY gone. (however dd off causes other stupid problems with fullscreen bs) buuut the lag is fixed.
@Goosekr I’ve got the Asus TUF OC 4070ti so apparently that lag problem is literally everywhere.
If anyone here can test the VP1 and see if they also have that lag problem on it it’d be appreciated. Or if anyone’s got any of those beta drivers…
Does the Pimax use USB relay for its motion tracking? I believe the Vive Pro does. Considering the tracking delay appears only in the headset tracking, and NOT in the controller tracking, that might mean something.
Welcome to the OpenMR!
:vulcan_salute::sunglasses::+1:
Thank you!
Your quite welcome! Feel free to DM me or @mention me if you have any questions or needs.
The system typically bumps your user level as you learn & use features of the forum I have bumped you & @Aelm user level by 1 for both of yous convenience.
Glad to hear it!
Seems to be affecting a lot of headsets on al sorts of hardware, thanks for sharing. The comment about Nvidia beta driver sounds promising at least.
where do i find the beta driver? cheers :slight_smile:
I also got the beta driver from Nvidia but it didn’t fix the lag.
They then gave me a registry key to add and that also didn’t fix the lag.
Where is the direct display option please? Anywhere I see online seems to instruct to change this in Steam VR but I don’t use Steam VR. Is there somewhere else I can set this or is it purely a Steam VR thing?
