Can We Get Acknowledgement of the Pimax Specific RTX 4090 Latency / Lag Issue please?
I also logged a ticket with Zotac and ram burn-in and stress tests. Everything looks and perform perfectly.
In 2D the 4090 works perfectly.
This is what Pimax said about my hand tracking module too. Then when you released the Pitool ‘fix for leap motion not detected’ it worked perfectly.
So I take it you are still not acknowledging the problem - it’s great some people have no issue, and it’s great removing Afterburner helps with some people. For me, I still have the issue.
So it is my problem and no help will be given?
Yeah it is very common tool folks install. Myself have jist stuck with the Zotac software.
2D is not as intensive as VR. VR everything has to be double rendered.
This issue will likely need to be evaluated by Nvidia and pimax. On some cards as pointed out with those using Afterburner has been a cause. We would need to see what all vendors are affected.
You have added Zotac without Afterburner being present.
Well yes obviously. I’m just sharing that I have done all the tests and log analysis etc with the card and it is not faulty.
Which is what is needed to help figure out root causes. It is posdible that Xotac is using there own kind of afterburner built into there software. So one thing to try us uninstall the Zotac utility software.
So I am the only person with this issue??
Again this is in everything including Pimax Home.
It is nothing to do with the 4090 being pushed to its limits. A straight swap to the 3090 with everything exactly the same is fine so it can run Pimax home but the 4090 can’t?
z590 Gaming Edge Wifi. i9-11900k. 64gb RAM. M.2 ssd.
I have installed only Nv drivers and Pitool, no other monitoring or overclocking applications. I keep it very clean and don’t overclock.
HX1500i.
I’ve tried on and off for all the bios setting such as gen 4, resizable bar etc. updated bios version to latest. I can’t resolve the lag.
I am not blaming. I am just asking for help.
BTW sorry for being so direct in all this but I have been troubleshooting and testing and swapping cards in and out for 10 days now and am just getting very frustrated at spending all the money and not being able to enjoy it. Editing this post as I can’t post any more here today.
You said the key words except the 4090. I would check with the reddit thread @vulcan78 linked as it is too early to say if your the only one not using aftetburner software.
Maybe Vulcan can ask in his topic there if folks are usung afterburner or not. If not what vendor cards are affected.
You and vulcan78 are pushing on Pimax to acknowledge that it’s their problem when that hasn’t been established. You both seem to be convinced that you have isolated it down to being a Pimax bug, but there are a lot of different components from different companies interacting in the video pipeline, and you really can’t make such a judgement about the culprit based on some isolation testing alone. It could be a bug with Pimax. It could also be coming from something else. It’s premature to blame Pimax as definitely the cause.
Seeking help from Pimax to get their analysis on the problem is indicated. It might be their fault, or their analysis might be able to help determine where its coming from. I’d just recommend asking for help on this without leading with the accusation.
I have bumped your user level as the forum system waa being problematic. I hope it has not caused you any inconvenience.
I am leaning at this point on the hypothesis that this is related to changes in the Architecture that is not playing well with monitoring software. similar to msi afterburner.
We saw something similar as I recall with fpsvr awhile back.
Thank you. Again I’m sorry for venting my frustrations. I am not blaming, but I am feeling kinda helpless. I am asking for help and trying to find a solution.
I have a ticket with Pimax Support but haven’t heard back since I provided debug logs last week.
As I said I do support Pimax and I sell how good they are to people all the time. And I don’t blame any individuals in support either. They do their best.
It is cutting edge technology and I get that it is complex. As I say if other brands had an issue I would look straight to Nvidia or Zotac. This does appear to be a compatibility between them - so it could also be Nv but it would require both companies to work together to some extent.
I’ve just kinda done everything I can at my end and have pretty much nothing left to try - but am absolutely open to any suggestions anyone has and I will test it out.
Note that even though the nVidia driver version may be the same, the 4090 may be using different parts of that driver package than the 3090 does. In particular, the support for the 4090 is new, while the code that’s driving the 3090 may not have been updated relative to previous versions of the driver package.
Yes I patiently uninstalled and clean installed the Nv drivers when swapping out cards in case there was some difference in installation when either 30 or 40 card was installed.
But yes it could be a change in how those drivers work absolutely.
My next option would be a full clean windows installation (w10 btw) but that is a pain I would rather not go through if it is not necessary.
Have you tried to uninstall Zotac’s monitoring software? As it’s monitoring software might use similar methods to msi aftetburner.
No monitoring software of any kind is installed. Just Nvidia drivers.
So no Zotac Overclocking utility or GPUz etc? Is HAGs disabled etc?
May need to do a deeper dive. With hopefulky finding another Zotac user.
No Zotac or overclocking software or any kind, no.
For the card testing I used GPU-Z and Furmark, subsequently uninstalled.
If it’s helpful for comparison, I’m using a Zotac 4090 Trinity OC.
AMD 5900X
ASRock Tai Chi motherboard.
nVidia driver 526.47 (10/27/2022)
Windows 10
I have not installed any Zotac software. MSI Afterburner was still there from previously when I tried some overclocking on my previous 3080 Ti. Have uninstalled that now.
Having no issues.
