Brand new 8K+ or used 8KX
They are at the same price.
Any opinion?
Perhaps the hardware has changed and a new 8K+ perform better than an old 8KX.
2 usb port ?? And the 8KX?
Here the 8KX has 2 USB ports too :
ok you talk about the small usb ports.
Yes he means to plug into the headset itself, not the cables going into the PC. The + has 2 ports, so you can plug in eye tracking + hand tracking into the headset… with the X, you’d have to run a long external USB wire to do both and only plug one in. Not a huge deal for regular users.
Speaking of. has anyone found a long usbc extension cable that is flexible and light.
The cable matters one are too thick and heavy
EDIT i was thinking. The oculus link cable is perfect and long enough but I just need a gender changer from usb-c male to usb-a female
something like this
this could work
Get the 8kX. There’s no question here.
It will have a better picture with less resource use than the 8k+ and you get high refresh rate and the same image quality as the 8k+ in upscale if you want.
For information, 8KX est dispo sur amazon eu
