Quite strong blur around edge of lens, is this normal?
Some blur is normal. I think that is true of all VR headsets. If it is particularly bad though maybe your IPD setting needs adjustment. I have found IPD to be difficult to get right.
Wouldn’t this be the case if the blur faded when i look directly at it, it’s always there no matter where i look, says to me its just the lenses, but i will try this…
Yep, IPD didn’t do anything, it’s just a side effect of the lenses…
