Title:Controllers not working
Describe Bug Below:I have tried eveything but cannot get the PIMAX controllers to be recognised in BeatSaber
Video if possible:
Steps to Reproduce
1.Tried with Pimax Play, Steam VR, Changing VR Runtime from Pimax to Steam Runtime
Pimax Hmd Model:
Firmware version:V1.0.12
System Info
OS:Windows 11 Pro
Build Version:26220.7670
CPU Model:9950X3D
Memory:96gb DDR5 5400
GPU Model/Brand:RTX 5090
GPU Driver Version:591.86
Upload Logs Below:
If the file is too large to upload directly, upload it to a cloud service (e.g., Google Drive, Dropbox) and share the download link.
Hello,
Could you please check whether the “Simulate as Index Controllers” option is disabled?
Do the controllers show up in SteamVR Home?
Are the controllers blinking in Pimax Play?
Please try resetting the controllers by holding the Pi button for 9 seconds until the light blinks red, then re-pair them.
Hello,
I have tried it with the controller enabled and disabled
Yes
yes they are blinking green in Pimax Play
Please try resetting the controllers by holding the Pi button for 9 seconds until the light blinks red, then re-pair them. -
the controllers have been reset 3 times and still nothing
Which headset are you using — Micro-OLED?
If so, we’re rolling out a patch that fixes the controller issue, including a compatibility problem with the OpenXR runtime.
So I doubt it’s the same issue you encountered.
Yes it is the Micro Oled which only arrived this week so that is indeed the problem that I have been struggling with for many hours trying everything I could think of - it didn’t make sense
Glad to hear it is being sorted so I can finally play BeatSaber
The patch should be ready this week, as the team is in the final testing phase.
is there an update on this ?
Our developers are in the final testing phase. If no major bugs arise, we’ll release it.
Hi
I have had no update on this - I’m using Pimax Play 1.43.7 and still cannot get BeatSaber working using the Pimax controllers - any advice please as this is driving me insane not being able to play this on my Pimax Crystal Super
I have tried enabling “simulate Index controllers” and making sure that the bindings are correct in the SteamVR app but nothing works
Thanks
Is the game being launched through OpenXR, or via SteamVR?
inside SteamVR - if I try to do it using the OpenXR runtime I get no display in the headset - it only shows when I use SteamVR with standard PimaxPlay open
Hmmm. This shouldn’t tho.
Could you try reinstalling Pimax Play and SteamVR?
Also, please verify the Beat Saber files through Steam to ensure nothing is corrupted.
