Asgards Wrath Firmware .262
We are talking about launching via Pitool :wink:
Revive is also being discussed however I also tried from PiTool and the gameplay was fine but the main menu was unusable.
is there already a fix?I have also the problems on the pimax 8kx…
asgard wrath and phantom cover ops the screen goes crazy
i am on the latest pitool and firmware… i also did try pitool 262 but the problem was also there
PT 261 or earlier…
indeed pitool 261 works,i hope there comes a fix soon @PimaxQuorra @anon57422158
Man I MUST play that game on 8KX why haven’t they fixed this yet?
So theres no issue with the 8kX and firmware 261?
will it prevent me from using the eye tracking and Pimax Experience?
@Miracle i know you said that the devs were working on a fix.
you cant use Pimax experience and i think eye tracking doesnt work good with that pitool version
Hey they just broke it in 262. The will need time to unbreak it :grinning:. In the mean time you can always jump back and forth between 261 and 262 (same fw) fairly quickly if you’re desperate to play AW.
I hate updating firmware because on my main pc it always fails.
so i end up having to unplug the pimax and put into my other media server pc and flash it over there with DFU.
so not convenient. :crazy_face:
You missed my point. You don’t need to change FW just install PT 261 or 262 as needed. They use the same firmware.
oh so its pitool eh? i wonder if it’s possible to install them side by side?
Maybe i install 261. rename the folder to pitool 261, and then install 262
then just rename the folders when i want to switch
Hope this gets fixed soon. Oculus games are some of the best out there.
Pimax has duplicated the issue and is working on it. Until then I would just install PT261 when I wanted to play AW or one of the other affected Oculus titles. and 262 if I wanted eye tracking. It only takes a few seconds to install PT. You don’t even need to do a clean install. Heck, PT installs faster than AW loads.
Apparently Phantom Covert OPS is affected too :frowning:
Come on PImax whats the deal? @Miracle
I just played that one the other night.
it worked! you had issues with shaky cam? and could get past the difficulty selection screen?
What piTool were you using because anything < 262 is known to work
any update on this @Miracle?
A bit late but you dont need to roll back that far to fix the issue. 261 is ok.
Ya I’d say a bit late lol.
If you note my more recent posts in this thread, I have been using 261 for some time.
Thank for the thought though Trev. :smiley:
Better late than never i suppose.
