# Any tips on cleaning the MAS?
**URL:** <https://forum.openmr.com/t/any-tips-on-cleaning-the-mas/39229>\
**Category:** Pimax Discussion\
**Created:** [September 5, 2022, 12:30pm UTC](https://forum.openmr.com/t/any-tips-on-cleaning-the-mas/39229 "2022-09-05T12:30:29Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![SmallBaguette](https://forum.openmr.com/user_avatar/forum.openmr.com/smallbaguette/32/24247_2.png) [@SmallBaguette](https://forum.openmr.com/u/SmallBaguette)\
**Post date:** [September 5, 2022, 12:30pm UTC](https://forum.openmr.com/t/any-tips-on-cleaning-the-mas/39229/1 "2022-09-05T12:30:29Z")
</div>
As the title suggests, looking for tips/success stories on cleaning the MAS. In particular, the foam on the strap. Also willing to buy replacements if anyone knows of any that are PU leather or such. I picked up a cheap secondhand SMAS that I was intending on modifying a bit and messing around with, but right now it’s rather grim and could do with a good cleaning. Don’t want to chance anything just yet and ruin the foam, I’m guessing a software soapy handwash will do the job but figured I’d post here first as in no rush.
Cheers!
**Post date:** [September 5, 2022, 2:48pm UTC](https://forum.openmr.com/t/any-tips-on-cleaning-the-mas/39229/2 "2022-09-05T14:48:36Z")
</div>
Alright, I know I said I’m in no rush but also was trying to procrastinate so ending up just chucking each part of the foam into the washing machine (just put each part into a sock to stop it getting damaged), and it came out perfect.
Before:
 ![image](https://community.openmr.ai/uploads/default/original/3X/6/f/6f5fe838cc8379fec666d3106f6a6e6c8dea561f.jpeg)
After:
 ![image](https://community.openmr.ai/uploads/default/original/3X/3/d/3d4f4d87bf6c50f54c762da8e31a16f56747d0c5.jpeg)
No damage to the foam or any misformation etc. Of course I’d probably not recommend it and do at your own risk, but it worked well for me (daily wash @30deg in with my normal washing).
**Author:** ![MeinFroschtrinkt](https://forum.openmr.com/user_avatar/forum.openmr.com/meinfroschtrinkt/32/24726_2.png) [@MeinFroschtrinkt](https://forum.openmr.com/u/MeinFroschtrinkt)\
**Post date:** [September 6, 2022, 10:45am UTC](https://forum.openmr.com/t/any-tips-on-cleaning-the-mas/39229/3 "2022-09-06T10:45:20Z")
</div>
I do wash my stuff from hand its no big deal, desinfections spray seem to result in damaging the face foams structure.
the back pad doe not seem to has this problems.
**Post date:** [November 5, 2022, 10:45am UTC](https://forum.openmr.com/t/any-tips-on-cleaning-the-mas/39229/4 "2022-11-05T10:45:56Z")
</div>
