I paid a computer guy $300+ to install an extra 4 MEGS of ram so I could play dune 20+ years ago.
omg good old times hehehe
i once bought a Packard Hell. First and last pre-made system lol. From then on it was p4,q6600, 2700k and now a 8700k.
I always picked good components, because you can see, i don’t upgrade to a new build often.
We can easily use the best computers and it is really working as good. And you have issues then go to technical support and which provide good support. I used the good system and but In this, Windows 10 some technical problem will occur. Many types of error code 0x80071a90 will occur. Then, contact the technical support to solve the problem. They provide good information.
